Retrofit front passenger seat lumbar support
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5723
Re: Retrofit front passenger seat lumbar support
It looks like they never had the option now - from the brochures I have found, - all reference is for the Driver and the wiring is different for each seat - as I've said the driver's seat controls the passenger one so you can't have 2 master seats with the same control ECUS - there will be conflict.
- qprdude
- My Cars: Renault 5 TS, Renault 14ts, Citroen C5 Mk1, Renault Clio sport, Renault Laguna Privilege. Citroen C5 X7 Exclusive. Citroen DS5 D/sport . And around 25+ other brands from Morris Oxford to S Type jag and most things between.
- x 10
It's probably not something I can be bothered doing James. I'm more hopeful that the wiring and lumbar cushion is present but not wired. I'm even more hopeful that a mobile office cushion will do. I believe there are inflatables now that can be adjusted to suit.
Rick.
2013 Citroen DS 5 D/Sport
- Stickyfinger
- My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally - x 1290
- Contact:
https://www.aircare-ergonomics.co.uk/back-supports
or fit this under the seat back cover ?
https://www.demon-tweeks.co.uk/motorspo ... -with-pump
Activa, the Moose Rider
3x C5x7 Steering racks and counting
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
I think that will be your best bet Rick - as cost cutting will probably mean the lumbar motors aren't there - consider that the driver's seat can be loaded with AFIL vibrators left and right, heated pads, multiple rollers and sensors, plus the lumber motors designed to double as the massage function.
I've just found from my dealer on another issue that they stopped producing the rear brake disc dust guards on many models now as part of 'trimming'. He said all of them literally start crumbling sooner or later and they now just pull them off which isn't difficult! So I won't be replacing mine that are also falling to bits at £40 a pop!
That link from Sticky is probably a cheaper instant solution!
