Automatic parking brake malfunction
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5723
Re: Automatic parking brake malfunction
If you do go hunting - it may be in the FSE (Electronic Parking Brake) ECU.
Hi all... i have Citroen DS4 dStyle and have the hand break issue too... i do not have the option to disable or enable it manually and when plugged it into diagnostic box it came up with c155d code but i can not find definite answer into how to fix it anywhere... anyone have an idea?
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
The C155D fault just means that automatic mode has been disabled and is low down on the rectification priority list as a 5 out of 6 with 1 being the most important.
When this happens, the handbrake goes into back up mode and you will have to apply and release the handbrake manually. You will lose Hill Start Assist and any other automatic functions.
This usually happens as a result of the ESP system (as the ESP system is responsible for managing the handbrake). So if there is a fault with the ESP system then it will have an impact on the handbrake auto functions. So I would start there.
