Xantia not starting
- daviemck2006
- My Cars: Far too many good ones to remember. Many BL, Vauxhall, Ford, Renault, Citroen, Peugeot, and now VAG
- x 488
Re: Xantia not starting
Well after tightening the clamps she had the phut to start bigpug, which was well down. At the end of the jump leads was getting 13.9 going into big pug. I gave her a cup of tea time before starting it.
There was a quick shower here a wee while ago, was that your tea Jim?
Skoda Karoq 1.6tdi 2018
Citroen relay camper 2012
In the family
Seat Leon 1.5tsi tourer 2019 daughter 1
C1 vtr+ 2010 daughter 2
In the family
- CitroJim
- x 6204
- Contact:
daviemck2006 wrote: ↑19 Dec 2017, 16:36 There was a quick shower here a wee while ago, was that your tea Jim?
No, couldn't have been as the tea was still in the kettle at the time - good job too
- daviemck2006
- x 488
So now, as I have done a few jobs to Gabby now, and Jim always says he has no problem with his nuts second time around, we can surmise that he only ever goes hand tight on his nuts
In the family
In the family
- white exec
Good news about Gabby starting, and having enough va-va-voom to get the big girl going too.
Always good to get a grip...
OnlineStickyfinger
- My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally - x 1297
- Contact:
I have this memory problem, which ones have I done ?, forgotten ?, not seen ?....I have resorted to TIPPEX now, I mark each bolt when, and only when, correctly tightened. On engine-2-part bolts, it has the added advantage (if you use a large "dollop") that you can see if a bolt has loosened and is equally useful at night if ever you need to find bolts in the darkness of an engine bay!
Activa, the Moose Rider
3x C5x7 Steering racks and counting
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 3008
Well, based on Michels oil filter problem, I know which way I would prefer things to 'fail'! (although I would prefer filters to remain reasonably securely in place). I recall having to take Bluebird to the local scrap yard to get a locking wheel bolt removed. It took them 45 minutes (and cost me £20) to break it loose (it also broke 2 correct 'keys', and eventually had a socket hammered onto it). She now has standard wheel bolts all round!
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- daviemck2006
- x 488
The lockers on my daughters audi were impossible for me to shift. It took a garage 2 hours to get all 4 off. I hate lockers with a passion, and usuallyone of the first things I do with any car I buy is consign them to the bin
In the family
In the family
- white exec
Not helped by tyre-fitters love of the rattle-gun, and aversion to a torque wrench. Invariably over-tightened.
- Michel
- My Cars: Some cars and a motorbike
- x 660
white exec wrote: ↑20 Dec 2017, 07:37 Not helped by tyre-fitters love of the rattle-gun, and aversion to a torque wrench. Invariably over-tightened.
Precisely why I always take my cars to the same place for tyres and have for 13 years. They do it properly, torque wheels properly, have no problem balancing centreless wheels. Great place. Small family run place in Binfield.
- CitroJim
- x 6204
- Contact:
Michel wrote: ↑20 Dec 2017, 09:08white exec wrote: ↑20 Dec 2017, 07:37 Not helped by tyre-fitters love of the rattle-gun, and aversion to a torque wrench. Invariably over-tightened.
I do the same but often I just take wheels as they're only at the other end of my road... They like that as it saves them a bit of work...
Was there any gap between the two halves of the battery clamps when they were loose ?
The usual reason for battery clamps coming loose unexpectedly is that the clamps are sitting too high on the tapered post and thus the two halves touch each other before the clamp is fully tight on the posts. Tightening the bolt just squeezes the two halves together tighter but doesn't squeeze any tighter on the post. So even though the bolt is tight and everything looks good if you give the terminal a good twist you'll find it lets go fairly easily...
To avoid this, if there isn't a gap of at least a few mm I always slacken the bolt off a few turns, use a flat blade screwdriver to spread the two halves and make sure it pushes further down the taper of the post then tightens up nicely with a gap between the two halves of the clamp. And then afterwards I try to rotate the clamp by hand to make sure it actually is biting on the post properly.
Sorry if I'm trying to teach you to suck eggs, but a lot of people don't seem to be aware of this potential pitfall of tapered battery posts...
Simon
1977 G Special 1129cc LHD
1978 CX 2400
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
- CitroJim
- x 6204
- Contact:
I think in this case it was me being very careful in tightening them Simon. I'm always very conscious of how delicate Xantia battery clamps are and act accordingly...
However, having said that it was a good six or seven months before Davie had her that I last had the battery out...
- daviemck2006
- x 488
There was a gap between the clamps as there should be, the earth had slackened and it just lifted off. The positive was tighter but still came off with a twist, si its connection could have been fine. She did a few miles of stop start deliveries last night with no problem. And at this time of year its all in the dark so heavy loads on the battery, but had 3 times to neighbouring villages which are 5 to 7 miles distant, always better getting one or two of them to give her a bit of a run.
In the family
In the family
- Michel
- x 660
Yes, that is the usual reason.
The other reason on Citroens that have been bought from North Bucks is that Jim's "tightened" them
- CitroJim
- x 6204
- Contact:
Another keyboard was at risk again then
From coffee this time!
