I found this whilst having a browse - one persons attempt at modifying the seal - I'm not endorsing the procedure, but interesting to see what others have to say about it. I think he makes his true feelings known almost at the end of the video (4:04)!
C5 X7 Hydraulics
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5741
Re: C5 X7 Hydraulics
- Stickyfinger
- My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally - x 1297
- Contact:
EDC5 wrote: ↑12 Dec 2017, 10:48Stickyfinger wrote: ↑12 Dec 2017, 08:47 On the ground, it is lateral movement when the joint is loaded that needs checking (I am told) so a lever bar between the joint and the bottom arm should show if it is worn. Mine did
https://www.frenchcarforum.co.uk/forum/ ... ower+joint
Does a buggered FRIP joint like that affect the handling in any way?
It did not seem to, but I could hear it on 1/2 lock/low speed. It would if it collapsed totally I think.
Activa, the Moose Rider
3x C5x7 Steering racks and counting
- Paul-R
- Donor 2023
- Lexia Available: Yes
- My Cars: 2015 1.6 Blue HDi 120 Peugeot 308 Active SW
2013 2.0 HDi 163 C5 Exclusive Tourer
2003 2.0 HDi 110 C5 Exclusive Estate (Gone)
2001 2.0 HDi 90 Xsara Estate (Gone) - x 1381
Yes, I saw that video as well. I'm not entirely convinced though. That grease nipple looks very vulnerable to damage although I suppose that it is protected by the bottom arm, etc.
- Stickyfinger
AX, little Daffodil
- Contact:
I would have put the nipple close to the edge under the bearing rather than under the pivot post/peg.
Yes, it looks easy to damage so why not close to the edge next to the arm bush ? might be better protected there.
Interesting modification but with a life of about 60k miles (guess) is it worth it with that type of joint which must have a limited life anyway?
- EDC5
- My Cars: Citroen C5 RHR AM6
- x 120
Stickyfinger wrote: ↑12 Dec 2017, 13:28EDC5 wrote: ↑12 Dec 2017, 10:48Stickyfinger wrote: ↑12 Dec 2017, 08:47 On the ground, it is lateral movement when the joint is loaded that needs checking (I am told) so a lever bar between the joint and the bottom arm should show if it is worn. Mine did
Right, it seems that I have knackered FRIPs then, I get a knock too at low speeds..... as well as the creaking!
As I say the handling is solid, nothing untoward at all....
So I'll put them on the list to change.... along with most of the front suspension components....
Before changing parts it may be worth switching into Sport Mode and seeing if the noise is less or disappears.
It worked for me and I later found an article on YouTube that explains that the Hydrsctive 3+ (no other) does not respond fast enough in comfort mode on bumps and is actually one wheel nominally leaving the ground and the hydraulics pushing it back down (you hear it not feel it as once one lifts the other stays firm.)
Of course, if running in sports mode makes no difference then drop link is the obvious (or strut bush/top mount.)
Worth a try as it is a no-cost test.
Mike
Mike
Current: C5 X7 Exclusive 2.0 HDI Manual (2008)
C3 Puretech 1.2 Feel (2017)
Previous: Citroen C5 mk1 2.0 HDI,
Peugeots 407, 406, 406,205,309, 306 Meridian, 306 L, Peugeot 207L 1.4 manual (2003)
- EDC5
- x 120
Filberton wrote: ↑13 Dec 2017, 13:58 Before changing parts it may be worth switching into Sport Mode and seeing if the noise is less or disappears.
Mike
The problem with the sports mode button is that it is no guarantee the car is actually in sports mode, it only lowers the threshold that the car will switch to sports mode.
I'm not sure if I can force it to sports mode through Lexia though.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
It’s worth a go as I can feel the difference immediately so know it’s in sport mode.
- My Cars: Citroen C5 X7
Same here, I definitely can spot difference when in sport mode. For the banging noise in the front suspension, when I turn on the sport mode and go over a speedbump, there's no banging noise (apart from my head hitting the car's roof) no matter how fast I go over a speedbump, so I'm note sure what to do here. In next few days I'll visit a service for a detail suspension check.
- EDC5
- x 120
I must admit to not feeling the difference in normal driving, it helps a lot with lateral roll but I'm not usually doing such manoeuvres normally.
I have in fact observed the transition to “hard mode” happening by taking the car for a drive whilst recording the suspension parameters with lexia. Even in normal mode it will switch to hard mode based on the thresholds of X,Y and Z acceleration. By switching sport mode on when parked then driving over a speedbump it will still in fact be in soft mode.
