Yes, I get that. But my question is what benefit is that?
C5 X7 Hydraulics
- Paul-R
- Donor 2023
- Lexia Available: Yes
- My Cars: 2015 1.6 Blue HDi 120 Peugeot 308 Active SW
2013 2.0 HDi 163 C5 Exclusive Tourer
2003 2.0 HDi 110 C5 Exclusive Estate (Gone)
2001 2.0 HDi 90 Xsara Estate (Gone) - x 1379
Re: C5 X7 Hydraulics
- My Cars: 2006 C5 2.0 Litre HDI VTR Automatic Estate.(now sold on)
Currently Renault Zoe 2014 ZE - x 2520
A good video but it needed a practice run before filming, then he would have had the calliper etc. out of the way first.
The levering tool could be better if it had a link down so that it could be foot operated to hold it down whilst the other work was done.
Certainly removes the need for a trip to the gym for exercise.
Man is, by nature, a lazy beast, he does not need twice encouraging to do nothing.
- My Cars: Citroen C5 X7
Thanks for the replies. I've checked the prices in few stores, and I will start with drop links, hoping that will fix the issue, if not I'll have FRIP examined. I have to decide which manufaturer of the drop links should I buy, so what would you recommend - Delphi, Sasic or Eurorepar (or maybe something else)? Genuine PSA spare is approximately 60€/piece, not sure whether it is a good idea, the others cost 20-30€.
- Stickyfinger
- My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally - x 1296
- Contact:
Easy to check the FRIP joint, it just needs a leaver bar with the wheels on the ground.
Activa, the Moose Rider
3x C5x7 Steering racks and counting
- EDC5
- My Cars: Citroen C5 RHR AM6
- x 120
xantia_v6 wrote: ↑11 Dec 2017, 03:23 The more I think about it, the more I am sure that the persistent problem with speed bumps is due to inappropriate (or at least marginal) damper settings in the corner spheres.
It may be possible to test the theory relatively easily by finding a car with the symptoms, and change the front spheres (at least temporarily) for some with softer rebound settings. The trick would be in identifying such spheres. Where does Sticky park his car? I actually suspect that HA3 (not HA3+) spheres would have the softer rebound damping required for this test.
This sounds interesting, I'd be up for testing this if I could find the correct spheres.
- Stickyfinger
AX, little Daffodil
- Contact:
Parked in Somerset, and no, you are not taking stuff off it
- bobins
- Donor 2023
- My Cars: Kia Sportage
Mazda BT-50
Land Rover SIII SWB
V-F-R800
SL320
MX5 - x 2892
I think we're going to struggle to come up with a definitive answer as to why they clonk going over speed bumps as it depends on what clonk is being referred to. One man's clonk might be another man's clunk ! I'm 100% certain that the clonk on mine going over speed bumps was nothing to do with the HA3+ system.... mainly because mine is on steel springs
Sadly no longer a C5 owner
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5741
I will get a 'bang' when going over one of those badly finished road drains where they have like a 3+ inch drop - that can be disconcerting as certain speeds - but always been like that and I never bother with it - not so much over speed bumps that I've noticed.
I'll try to record a banging sound bofore going to a mechanic, and I'll post it so we can compare different bangs and clonks
- milleplod
- My Cars: 2009 Citroen C5 2.0HDi Exclusive Tourer
(Previously, in order....Dyane, 2CV6 x 3, Visa 1.7D, GSA estate, GS Pallas, CX TurboII, Picasso...all fondly remembered!). - x 15
They're 2 quite different noises. The drop links sound like a light, pattering sort of knock when going over multiple road-surface imperfections, and an occasionally louder, but still lightweight, knock over single smaller holes. The other sound is definitely a bang, enough to make you think 'WTF was that??!' - its not heard at all over road imperfections unless the front wheels fall into a deepish pothole, for example.....or you go over a speed hump that has a quite steep profile on its 'departure' side, again when the wheels drop to the lower surface.
I know what I mean anyway!
Pete
Pete
Nocto Diuque Venamur.
I'm quite sure I have the second one
- Stickyfinger
AX, little Daffodil
- Contact:
Yet I am quite sure I have neither sound....so what is different between some cars and others ?
Stickyfinger wrote: ↑11 Dec 2017, 12:22 Easy to check the FRIP joint, it just needs a leaver bar with the wheels on the ground.
With the wheels on the ground or off the ground? I've seen some videos for checking the frip, but each of them had the wheels off the ground. If that's not correct can you explain the procedure?
- Stickyfinger
AX, little Daffodil
- Contact:
On the ground, it is lateral movement when the joint is loaded that needs checking (I am told) so a lever bar between the joint and the bottom arm should show if it is worn. Mine did
https://www.frenchcarforum.co.uk/forum/ ... ower+joint
- EDC5
- x 120
Stickyfinger wrote: ↑12 Dec 2017, 08:47 On the ground, it is lateral movement when the joint is loaded that needs checking (I am told) so a lever bar between the joint and the bottom arm should show if it is worn. Mine did
Does a buggered FRIP joint like that affect the handling in any way?
