What does this fault code mean?
'13 3008 1.6 HDi GripControl - x 1003
Re: What does this fault code mean?
I suspect that if you just change the block and not the computer, then you won't need to configure it all. As to how easy it is to get them apart....
The service docs don't seem to imply it's difficult to separate. It might be that the actual block is common, and only the ECU is different - difficult to tell as there's no separate part number. You would need to match the maker's numbers to confirm this. The part numbers don't match against any other cars, but the pictures of the diagrams on later ones look similar, but that might be artistic licence!!!
- Bandit12
- My Cars: C5 X7 diesel exclusive
- x 12
An update guys - all fixed! Fitted a replacement block and module from eBay, bled brakes, switched on car following bsi reset procedure and all warning lamps are off n brakes working perfectly.
Result, thank you very much
Bandit
Bandit
2002 Citroen C5 2.2Hdi exclusive estate (sadly gone)
2009 Citroën C5 X7 2.0 hdi (136bhp) exclusive estate (Oh wow what an upgrade)
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5741
Well done - great news!
- My Cars: Citoren C5 / 2.2 Automatic / Estate (2005) || VF7**************[VIN obfuscated, can be read by forum staff]
Project name: The Mothership
I believe this is a common fault with the com2000 steering wheel CPU dept.
