That depends on whether they have a manual or automatic gearbox (amongst other variables).
Why does my C5 want to drive in circles???
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 3008
Re: Why does my C5 want to drive in circles???
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- My Cars: Currently:
In the past: 3, CX td Safaris and about 7, XM td estates. Lovely cars. - x 1207
About 3 years I had a similar problem with an XM, always pulled to the right, never suspected the tyres as it had a couple of new Goodyears on the front, once they wore out and I changed them - problem cured, so as suggested, try swapping them around.
So Update at last...
the third tyre centre that i took it to was Kwik Fit but they only had a "normal" tracking rig
after the suggestions on here to get the full geometry checked i called a different Kwik Fit who had one of these machines
they advised that the check was free. costs were only incurred if changes had to be made...seemed reasonable
when they checked the tracking was quite literally off the scale
they corrected the tracking and replaced two back tyres (which definitely needed doing) and revealed me of £150 (which i thought was reasonable for the work done and tyres)
and now it steers like it should do. the only thing i can think off is that the bushes were so worn that standing still everything checked out fine but under load everything was out of line. once i replaced the bushes everything was held out of line even standing still and once this was corrected it all lines up and works as it should
the thrust line check also shows my OSR wheel was running just a little bit out of alignment Kwik Fits Technician said it was too small to worry about and there was no way to adjust it anyway
guess what... four month later and i have just replaced the swinging arm bearings after i started getting that clacking sound that signals they are on the way out
so its taken a while (nearly 2yrs) to get everything right and i will never use the original tyre centre again
thanks guys for your suggestions i hope my final results helps someone in the future
UVG
UVG
- Zelandeth
- My Cars: 2006 Peugeot Partner Escapade 1.6HDi.
1988 Renault 25 Monaco 2.0i.
1985 Sinclair C5.
1984 Trabant 601S.
1975 Rover 3500.
1973 AC Model-70. - x 1406
- Contact:
Glad you got it sorted. It's astonishing how useful someone with a decent 4-wheel laser tracking rig is when they know how to use it.
Current fleet:
06 Peugeot Partner Escapade 1.6HDi, 88 Renault 25 Monaco, 85 Sinclair C5, 84 Trabant 601S, 75 Rover 3500, 73 AC Model 70.
