Sorted as much as its going to be for the retest Mick.mickthemaverick wrote: ↑19 Feb 2022, 18:46Ah right, have you sorted the exhaust now, can't remember!![]()
I think I've done all I intend to do. I found I had a new set of spark plugs lying around and although I've done the job, before on a Clio, i decided not to bother. They are buried down some very large holes and require this tool (the long metal tube), to remove them, and then there's stuff to disconnect/remove to get at them, so rather than disturb things I didn't bother. I will have some feeler gauges somewhere but haven't seen them for years, gap supposed to be 0.9 mm.NewcastleFalcon wrote: ↑18 Feb 2022, 00:06Remade the joint between the back box and middle pipe which was leaking using this stuff today, decent enough break in the weather sunny, and Dudley had blown over mostly during the night...
The other thing in the pic is a good little tool for removing the oil filter, because its in the most awkward of locations matches the flutes at the end of a proper spec Clio 2 Oil filter.
