I've just acquired a 1997 Xantia. The plip doesn't work and its only got one key. I'm not too fussed about not being able to "plip" it to lock and unlock, but is it possible to get another key cut? Should be simple enough, but I was wondering whether the size of the plip bit would make it tricky for a key cutter.
As an aside, I love the car - the 2.0 16v engine can shift a bit when it wants to! Touch wood it will be okay - had a new heater matrix, clutch and cambelt over the last 18 months so fingers crossed that nothing will go wrong for a bit!
Back to Citroen - Xantia Key idea
- My Cars: Current:
Volvo V60 D4 180
Previous:
BX16RS (two of),
BX19TZI,
Xantia 2.0i saloon,
Xantia 2.0 Exclusive CT turbo Break,
Peugeot 807 2.0 HDi 110,
Renault Grand Scenic, 2.0 diesel (150bhp)
C5 X7 2.0 HDi 160 which put me off French cars possibly forever - x 16
I tried to get a key cut for a Xantia a few years ago and was told (by several key cutters) it couldn't be done by the usual method of copying the key to a blank due to the notches in the broad side of the key.
Of course things may have chaged since then.
The alternative is to get a Citroen dealer to have one made up. You should have a card with the key code, if not they may be able to find it from the chassis number.
- My Cars: Current:
Volvo V60 D4 180
Previous:
BX16RS (two of),
BX19TZI,
Xantia 2.0i saloon,
