removing gearbox
- froggy
- Donor 2023
- My Cars: S2 Xantia Forte 185435.
Peugeot 306 Meridian, the boss. - x 2
Re: removing gearbox
That's, great Jim , many thanks, keep you informed.
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
- My Cars: 2008 Laguna 1.5 DCi
- x 235
It's a good idea to change the seals after you remove the gearbox, cheap items but from experience on a Xsara very annoying when they start dripping your new gear oil on your driveway. I couldn't get the Xsara carrier bearing to move so I loosened the carrier and managed to get the gearbox out. There's more hammering room then but I think I damaged the seal doing that
Oh buggle
- froggy
- Donor 2023
many thanks, just removed the gearbox, hammer and blunt chiesel a 'Gods send'. came off after a couple of smacks . The release bearing is badly worn as I thought. many thanks again.
Terry
- Oldpug
- My Cars: Peugeot 406 GLX
Audi A3 TFSI S Line
Mercedes SL320
(In the past,just about every old Peugeot you can think of.) - x 64
Follow CitroJim`s advice,that shaft needs to be removed completely, then the box will just fall off.
Beware though,now that you have been yanking it around with the shaft still in the box,you may have damaged the plastic speedo drive gears. Also make sure both CV`s are still intact?
- CitroJim
- x 6208
- Contact:
And it's likely the driveshaft oil seal will be damaged too... Replace both seals as a matter of course
- froggy
- Donor 2023
many thanks.
Terry
