[1999 1.9D DW8] I know idling a diesel is bad for it, but how bad?
Michel
(Donor 2022)
My Cars: Some cars and a motorbike
x 660
Re: [1999 1.9D DW8] I know idling a diesel is bad for it, but how bad?
Post by Michel »
CitroJim wrote: 23 Nov 2017, 17:19
Peter.N. wrote: 23 Nov 2017, 15:34 I can remember in the '50s the drivers lighting a fire under the engines to get them to start in very cold weather.
Yes, now you say I remember dad telling they did the same and even lit fires under the fuel tanks as the diesel would begin to gel in the cold...
My dad had a LWB diesel Landie when he worked at Dinorwig Hydro station which used to get a fire lit under it in winter. I remember it from being a kid.
The landie met it's fate when he forgot to put the handbrake on one day up Snowdon..
moizeau
My Cars: 91 BX TZD Estate. Dead but loved
407 HDI 136 auto
C4 2l petrol coupé
2010 Dispatch III HDI 90
AND a 1980 Z1000ST
AND a 1983 GPz1100 inj
AND a 1995 Zephyr 1100
AND a 1980 Z650 (my moped)
x 317
Post by moizeau »
With a Landy, never use the hand brake, just leave it in 1st, it'll go nowhere
Pete
doctle
My Cars: 2008 Laguna 1.5 DCi
x 235
Post by doctle »
This can be a problem on small single cylinder air cooled diesels but it shouldn't be a problem on your van. The small engines run cool unless they're under a load of maybe 60% this can cause excessive carbon build up and wet stacking. The 1200 rpm is a good idea.
Oh buggle
My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
C5, C5, Xantia, BX, GS, Visa.
R4, R11TXE, R14, R30TX
x 4922
Post by myglaren »
I did wonder briefly if a dedicated diesel genny might fit the bill but the bill would probably be too big - they 'aint cheap :(
Rosanbo
My Cars: CITROEN C4 PICASSO EXCLUSIVE E-HDI 115 AIRDREAM (2013 MK2) (DV6C engine)
x 3
Post by Rosanbo »
Can someone please explain the mechanism for using a shot cartridge to start the tractor?
Does the shot cartridge have actual shot in it? Where does the shot go?
or are they special blank cartridges?
doctle
x 235
Post by doctle »
Oh buggle
doctle
x 235
Post by doctle »
myglaren wrote: 23 Nov 2017, 19:22 I did wonder briefly if a dedicated diesel genny might fit the bill but the bill would probably be too big - they 'aint cheap :(
Diesel generators are like women, good ones arent cheap and cheap ones arent good
Oh buggle
Rosanbo
x 3
Post by Rosanbo »
Ah yes, like in flight of the phoenix (1965), thanks
Zelandeth
My Cars: 2006 Peugeot Partner Escapade 1.6HDi.
1988 Renault 25 Monaco 2.0i.
1985 Sinclair C5.
1984 Trabant 601S.
1975 Rover 3500.
1973 AC Model-70.
x 1406
Contact:
Post by Zelandeth »
Those Field Marshall tractors are something else...single cylinder two stroke diesel of something around six litres in capacity. They tend to make the ground shake at idle...
Current fleet:
06 Peugeot Partner Escapade 1.6HDi, 88 Renault 25 Monaco, 85 Sinclair C5, 84 Trabant 601S, 75 Rover 3500, 73 AC Model 70.
My Cars: Currently:
In the past: 3, CX td Safaris and about 7, XM td estates. Lovely cars.
x 1207
Post by Peter.N. »
One of our local farmers has a 'Field Marshall' tractor and we can hear it running from two farms away!
A friend of ours who lives over the border in Devon has a wonderful collection of tractors and old stationary engines of the 'hot bulb' type, you have to heat up the bulb with a blowlamp until its pretty well red hot and then swing the engine, if its hot enough it will start. He also has a tractor that you start by unscrewing a holder from the cylinder and inserting a rolled up piece of saltpeter impregnated paper, this continues glowing after you have refitted it and if you are lucky it fires up when you turn it over.
This is the same chap that dug out our 300 year old well and reinstated it, what he doesn't know about country crafts is not worth knowing, mind you he is the same age as me so not quite so active now, also has a broad Devon accent.
doctle
x 235
Post by doctle »
I think the Field Marshall is similar to the Lanz Bulldog they were hot bulb engines too but semi diesel, they run on any kind of oil. Great sounds at vintage shows
Oh buggle
Donor 2023
Lexia Available: Yes
My Cars: 2015 1.6 Blue HDi 120 Peugeot 308 Active SW
2013 2.0 HDi 163 C5 Exclusive Tourer
2003 2.0 HDi 110 C5 Exclusive Estate (Gone)
2001 2.0 HDi 90 Xsara Estate (Gone)
x 1379
Post by Paul-R »
Semi diesel? Is that like being a bit pregnant?
"Trying is the first step towards failure" ~ Homer J Simpson​
doctle
x 235
Post by doctle »
They'd run on straight used engine oil too, maybe I'll convert the streak (307) but there may be some health and safety concerns.
Reason: YouTube embedding.
Oh buggle
lexi
My Cars:
x 138
Post by lexi »
Another interesting start method.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
My Cars: Currently:
x 1207
Post by Peter.N. »
Yes Iv'e seen a few of those 'engine start' engines on you tube, mostly Caterpillar but another engine that Iv'e never seen but read about was the 'Hessleman' engine, a low compression direct injection engine with spark plugs, I wouldn't think it was very efficient but you could run it on practically anything that burns.
Post Reply
