Dead key
- Paul-R
- Donor 2023
- Lexia Available: Yes
- My Cars: 2015 1.6 Blue HDi 120 Peugeot 308 Active SW
2013 2.0 HDi 163 C5 Exclusive Tourer
2003 2.0 HDi 110 C5 Exclusive Estate (Gone)
2001 2.0 HDi 90 Xsara Estate (Gone) - x 1383
Re: Dead key
You put the working key into the ignition, turned it and then went through the procedure on the non-working key?
- My Cars: Current:
Volvo V60 D4 180
Previous:
BX16RS (two of),
BX19TZI,
Xantia 2.0i saloon,
Xantia 2.0 Exclusive CT turbo Break,
Peugeot 807 2.0 HDi 110,
Renault Grand Scenic, 2.0 diesel (150bhp)
C5 X7 2.0 HDi 160 which put me off French cars possibly forever - x 16
Re: Dead key
But surely it will be powered by induction (hence the transponder coil), not from the fob battery.GiveMeABreak wrote: ↑14 Nov 2017, 11:02 Hmmm... Not so sure Paul - this extract (for the X7 at least) would indicate that the Ignition Key Transponder also has some ability to perform a calculation. Probably another reason why the X7 only has the electrical remote fob if this is the case.
First - clarification of the terminology using this diagram:
(1) Ignition key with integral transponder.
(2) Transponder coil .
"a" Ignition key transponder.
Anyway that seems to be proven by the car starting with the fob battery removed.
- Paul-R
- Donor 2023
Re: Dead key
That's for the transponder chip to be interrogated which is completely separate from the lock/unlock mechanism.
Whilst we all agree that ideally the key should be re-paired my contention is that it's not necessary if only the lock/unlock is needed.
The battery is ONLY for the lock/unlock. As you say the transponder chip gets its power from the coil.
