Asin 6 speed auto - Clunk
- Sloppysod
- My Cars: Citroens
1 x GS, 1 x GSX (Banger raced), 1 x GSA,
2 x CX Famililles, 1 x CX GTI,
BX, XM, Xantia, C5 Mk1,
C4 (Coupe), C4 (B7),
C5 (X7) - RIP April 2024
Renault
R4 Van
Fuego
Clio Campas - x 216
Re: Asin 6 speed auto - Clunk
Thanks EDC5, so that little round 'tank' with two pipe connectors just below the control block is the cooler/heat exchanger and does both, heats and cools the gearbox oil.
Stu
Major interventions
C5 Steering rack @ 58,000 mi
4 discs & Pads @ 63,585 mi
2 (AM6) oil exchanges @ 58,876 & 72,378 mi
Major interventions
OnlineGiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5727
Here Stu:
Capacity is 7 litres of oil, 4 litres remaining after draining 3 litres using procedure.
The gearbox must be drained when the oil is hot (60 °C minimum), to eliminate the impurities suspended in the oil.
Procedure:
Draining
Put the vehicle on a hoist. (remember to raise suspension and remove LDS cap if suspending with wheels hanging free)
Remove :
The protective panel under the engine
The top-up plug (2) ; Using a TORX socket wrench
The oil overflow and drainage plug (1) ; Using a 6 -sided wrench
Approximately 3 litres of oil should flow out.
Refilling
Refit :
The oil overflow and drainage plug (1) (equipped with a new seal)
The top-up plug (2) ; Using a TORX socket wrench Remove :
The air filter housing
The filler cap (3)
Refit the filler plug (3) (equipped with a new seal).
Initialise the used oil counter (follow the diagnostic tool procedure).
Check the oil level
Prior conditions:
Stream of oil then reducing to a sequence of drips:
Refit the oil level plug (2).
Sequence of drips or nothing:
Refit the oil level plug (2) (equipped with a new seal).
Check the oil level (continued)
Refit :
The filler cap (3) (equipped with a new seal)
The air filter box
Too high a fluid level can cause:
Overheating of the fluid
Fluid leaks
Too low a level will lead to destruction of the gearbox.
You have the Euro 5 engine, so AW-1 oil.Capacity is 7 litres of oil, 4 litres remaining after draining 3 litres using procedure.
Procedure:
Draining
Remove :
Refilling
Refit :
The filler cap (3)
Check the oil level
Prior conditions:
- Vehicle level
- Check that the gearbox is not in downgrade mode
- Remove the filler plug (3)
- Add 0.5 additional litres of oil in the gearbox
- Apply the brakes firmly and move the lever through the various selector positions
- Gear lever in position "P"
- Engine running at idle
- Oil temperature 60°C (+ 8 ; - 2 °C) (measuring of parameters using a diagnostic tool)
- Refit the oil level plug (2).
- Stop the engine.
- Add 0.5 additional litres of oil in the gearbox.
- Repeat the top-up procedure.
Refit :
The air filter box
Fluid leaks
- Sloppysod
- My Cars: Citroens
Renault
R4 Van
Fuego
Clio Campas - x 216
Thanks Mark from the info, search around the site has given me some more information, sump seals etc, but the oil has got me stumped. I need AW-1!!
However, here's the rub, I have been told by Opie oils that "The 3309 cannot cover the AW-1, but it does work the other way round. AW-1 can be used in place of 3309. Its all marketing really." and they can supply AW-1 spec oil from G-Force but further hunting expands to G-force oil actually is manufactured by Gazpromneft Lubricants’ who are Russian, and I am not confident about the quality
Stu
Major interventions
Major interventions
- white exec
Perhaps not a good idea to be putin that Russian oil in the box.
Worth just getting the proper stuff from Citroen?
- Sloppysod
- My Cars: Citroens
Renault
R4 Van
Fuego
Clio Campas - x 216
white exec wrote: ↑14 Oct 2017, 17:54 Perhaps not a good idea to be putin that Russian oil in the box.
My thoughts exactly, but as I expect to be buying 8-10 litres of the stuff I need to find a better / cheaper supplier.
Stu
Major interventions
Major interventions
- white exec
There are some occasions where price shouldn't be the prime consideration, and modern 'box oil is one of them.
You won't be doing this very often, after all.
Just putin my two penny'worth in... again...
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
Stu
Here is a Total equivalent that states it meets AW-1 specifications - it is TOTAL FLUIDMATIC MV LV
One UK supplier:
https://www.alza.co.uk/hobby/total-flui ... toChange=1
One UK supplier:
I have just bought 10 litres of Total Fluidmatic MVLV from http://specialisedproducts.co.uk/ for the gearbox on my C6. I visited them in person and they were very helpful. I do not know if they would post.
2009 C6 2.2 Hdi Exclusive Gris Fulminator
1999 XM 2.0 TCT Balmoral Blue Nacre
1987 2CV6 Rouge Vallelunga
1979 2CV Fourgonette (by Villevans) Cormoran Gris
1981 Midas Silver
1972 D Special Black (gone but not forgotten)
1981 Midas Silver
- CitroJim
- x 6185
- Contact:
I would definitely concur that it would not be wise to skimp on the ATF. I'd only use exactly as advised by the manufacturer.
I'd not even use one that says it's compatible with what's required following a lot of research into the ATF requirements of the ZF 4HP20 'boxes...
- Sloppysod
- My Cars: Citroens
Renault
R4 Van
Fuego
Clio Campas - x 216
I agree with most of the above, hence the reason why I did not buy the Russian stuff. I understand you pay for what you get, however, the gearbox is not Citroën, it is Aisin Warner and fitted to a lot of cars, Fiat, Ford, Toyota, Volvo and Vauxhall just to name a few.
I am also not going to buy an oil that says it is compatible with AW-1 and JSW3309 or any other older spec, because they all have different viscosities as shown on the datasheets and a Aisin Euro 5, needs a low viscosity ATF.
Thanks again, Stu
Thanks again, Stu
Stu
Major interventions
Major interventions
- EDC5
- My Cars: Citroen C5 RHR AM6
- x 120
Do you think there is any longevity difference between JWS3309 and AW-1?
I'm assuming AW-1 is thinner to reduce drag, but does it lubricate just as well?
- Sloppysod
- My Cars: Citroens
Renault
R4 Van
Fuego
Clio Campas - x 216
I am not sure, about if it lubricates better or not, but there is a possibility that when Aisin made the Euro 5 mods they made some oil ways smaller, therefore if you Put a thicker oil in a box designed for a thin oil you could have problems. As Opie said AW-1 will go in JSW3309, but not the other way around.
Stu
Major interventions
Major interventions
- EDC5
- x 120
Ah ok, I see. I was just curious if Aisin changing the gearbox oil was the only thing between Euro 4 and 5 certification
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
So I'm just going to throw this in for debate as I think it is relevant to this whole 'Euro' Engine / Emissions standard debacle.
[1] - The procedures state:
[2] - Next, regarding the PSA / Euro Designations
The PSA 'Levels' are not the same as the 'Euro standards' on some VIN specifications, so be careful. So where it says 'Vehicle Technical Depollution' or 'Emissions Standard (Engine)', the 'L4' or 'L5' does not correspondent to the Euro Standards. See the following table for equivalents: As an example - here is an extract from the relevant VIN specs, from two C5 (X7) DW10BTED4 engines. One is a 2008 and one a 2009 model. Note the first one (2008) refers to 'L5', but it is actually a Euro 4 engine. The second (2009) actually now states 'Euro 5' Although it might seem the engines are the same - they are not quite - the 2008 is an 'RHR' (100 kW) and the 2009 is an 'RHF' (103 kW)
[3] Now look at the engine codes table below
According to this table both the RHR & RHF DW10BTED4 engines (referred to above) are under the 'ENGINE TYPE EURO 4' Column.
So the wider question now is
Ok, so that makes sense so far.The oil type "AW-1" in AT6 and AM6 gearboxes with engine version Euro 5 is specific and cannot be replaced with oil type "JWS 3309"
- Are ALL these engines listed in the table actually Euro 4 engines?
- Are ALL these Euro 4 engines as a minimum, but may, depending on your engine code & VIN Specs. actually be Euro 5 compliant?
- Are we more confused now than ever?
- bobins
- Donor 2023
- My Cars: Kia Sportage
Mazda BT-50
Land Rover SIII SWB
V-F-R800
SL320
MX5 - x 2891
Interesting investigation, Marc. It might explain why I ended up with a Euro 4 German emissions sticker for my car ! I'd sent a copy of my V5 to a mate who got an emissions sticker from his local garage for me. I was expecting it to be a Euro 5 sticker, but I got a Euro 4 one. My engine is a 2009 RHF variant. It may be down to the fact that they weren't really concentrating too much at the garage though
Sadly no longer a C5 owner
