C5 Mk 1 front suspension issue
- tontonjon
- My Cars: Deep Purple Mk2 Cactus manual and Emerald Blue Mk2 Cactus automatic
Used to own 1970 DSuper and 2003 C5 - x 7
Re: C5 Mk 1 front suspension issue
Good point. Profile updated.
hi tontonjon its possible your strut is damper seals is leaking badly. This leakage will goes to the return pipe beside the damper strut at the bottom n goes back to the reservoir. You still can run it for sometime but the return pipe will burst one fine day so you better source for a used strut if you tight on cash.
- tontonjon
Thanks for that. I'm hoping so, as a new strut is with the mechanic now. I also hope that he is fixing it right now! I bought a new strut as although I don't have a lot of money at least there's a guarantee it will last. It'll see the car through the rest of its life, no doubt. I'll let you know how it goes.
- tontonjon
Final note: problem now solved. It WAS the front right strut, leaking badly. To test, the mechanic pulled off the return hose and fluid shot out.
Final price: £360 for strut and two bottles of LDS + £48 for labour. A bargain to keep my fabulous car on the road - and another C5 saved from the scrap yard!
Good to hear that you got it solved. Lets hope your machanic don't get drown in 2 litres of LDS. Enjoy your new audio set and don't worry about adding more amplifiers and speakers as they are independent from the suspension and engine wiring. I already upgraded the s**t alpine set and stock speaker in my C5 to a much better pioneer unit. The difference is night and day.
- tontonjon
Update: suspension still holding up and the ride is fabulous. The right side is settling slightly lower than the left, though: is it possible to adjust this? Is this an anti-roll bar/height sensor switch issue?
- myglaren
- My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
C5, C5, Xantia, BX, GS, Visa.
R4, R11TXE, R14, R30TX - x 4922
Following my similar repair I found that for a few days the offside was lagging the nearside but it is all back to normal now.
I do perform Citroebics often, usually at least once per journey,
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
Do as Steve says - it should settle down, but the left and right height correction are not separately adjustable.
- tontonjon
That's good to know and what I had hoped. A new strut v one that has done over 115000 miles aren't going to perform in exactly the same way (or are they?!), so I shall wait and see if the new one settles as you suggest it might.
Thank you!
Thank you!
