Retrofit Electrochrome Mirror to C3 Picasso
- My Cars: Now:
C5 X7 HDi 240 Exclusive Tourer
ZOE 22kwh Intense
Before:
C4 1,6 Coupe Automatic
C5 X7 HDi136 Exclusive Sedan A
Xantia HDi110 Berline
Xantia 1,8SX Berline - x 28
Re: Retrofit Electrochrome Mirror to C3 Picasso
Electrochrome door mirrors have lines that go around the edge of the mirror glass (they look a little like rear window heater lines) - my -08 C5 X7 didn't have those lines. So you can see right away if mirrors are electrochrome or not.
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5741
I think I already mentioned - whether you got them or not was dependent upon year and option pack - they changed between 2008 and 2009 in the UK as per the brochures I have.
- My Cars: Now:
ZOE 22kwh Intense
Before:
Yes, but you can have that on/off switch without dimming outer mirrors.
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 3008
I must have really got lucky with MY mirror. Not only does it fit the wiring, and turn off when the electrics are off, it also has an On/Off switch!
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- patriotbarrow
- My Cars: 2009 Citroen C3 Picasso
GiveMeABreak wrote: ↑02 Oct 2017, 13:26 You could - if it will fit the C3, and if you remember to turn it off. Before I located the correct feed for my front and rear Dash Cameras, I had it on a permanent feed and forgot to turn it off several times. I left the car for a few days and had a job to start the car the next time! Managed to piggy back a switched feed from the electric seats now the cameras just turn on and off with the car after a 5 second delay. Perfect.
A rather simple solution would be to somehow (emphasis on the "somehow") run power from the electric window button lights, as they are turned off the moment you open the door. I guess it isn't maybe as simple as it sounds.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
You shouldn't really run anything off another bit of equipment on multiplexed cars to be honest - you are better off taking an appropriately fused feed from the fuse box, by using a piggy back fuse. Splicing into the wiring of the other electronics is asking for trouble - you could interfere with the operation of the vehicle or cause further electrical problems. There may be in excess if 26 ECUs dotted about the car controlling everything from the windows, doors, mirrors etc. There is a door control module in the door that deals with mirrors, doors, windows and lots of other things depending on equipment an options - upsetting any of these may cause intermittent or unexpected behaviour.
- patriotbarrow
I think I may have found a solution to the power conundrum.
Reason: Removed dead video link
