Gibbo2286 wrote: ↑28 Aug 2017, 19:20
I'm not sure, maybe it means that the door needs to be closed for the window ecu to be initialised. Complicated stuff this French electrics.
I mean the first part with window motor ...
GiveMeABreak wrote: ↑29 Aug 2017, 16:24
- When it reaches the top, hold the button for a few seconds and let go.
GiveMeABreak wrote: ↑29 Aug 2017, 18:09 Ok, I can see when you keep pressing the button to raise the window - keep holding the button - don't let go. When it gets to the top keep it pressed and listen very carefully and you might hear a slight click sound - that is the initialisation. Then let go. If you keep pressing and letting go you are using the auto function.
