Converting Xantia strut tops
- white exec
Re: Converting Xantia strut tops
An engineer will have to take the Activa unions, and plug the threaded hole in them (which previously took a 10mm pipe), and re-drill and tap a new thread for your 3.5mm screw-in unions. The drawing above should help.
- My Cars: '95 Xantia 1.9D automatic - 118k one of two? remaining
'97 306 1.6 XS, 24k, The ex-Haynes "Max Power" display car. Bought after being written off & stripped, now being rebuilt without the wide body
'96 ZX 1.9TD SX, 81k new resurrection project saved from the scrapper - x 216
white exec wrote: ↑31 Jul 2017, 13:32 An engineer will have to take the Activa unions, and plug the threaded hole in them (which previously took a 10mm pipe), and re-drill and tap a new thread for your 3.5mm screw-in unions. The drawing above should help.
Either this, or couldn't same engineer scratch-fabricate a dedicated screw in plug that can be loctited into the strut top, with the 3.5mm fitting drilled into it? Just thinking, Activa unions surely aren't required as a starting point & might be easier to start with a simple piece of round bar machined to fit?
'97 306 XS 1.6i, Blaze Yellow, 24k
'96 ZX SX 1.9TD rolling shell, White, 81k
- white exec
You could be right. Activa union without its 10mm bell-ended pipe probably wouldn't seal anyway, without thread sealant.
That was my thoughts too, it'd require Loctite/epoxy or similar to seal the threads anyhow so it'd probably be quicker/easier to make an adaptor from scratch (unless one used the idea of brazing to a section of Activa 10mm pipe of course)
