Sent from my SM-G361F using Tapatalk
My TD Xantia and XM were more economical and smoother running on straight veg oil 100% mix.Paul-R wrote:Question.
Veg oil is generally cheaper than pump diesel but does it have the same, or similar, calorific value? What difference, if any, is there in the MPG comparing the two fuels?
daviemck2006 wrote: 11 Jun 2017, 20:04 I assume that this is the fuel pump on the berlingo then. And I also assume that given the fact that Lucas is embossed into that black electrical connection means veggie oil is a no no for it.
CitroJim wrote: 12 Jun 2017, 15:27 If it's as good as Gabriel then you'll get well north of 50 mpg if you drive it with some care Davie...
van ordinaire wrote: 12 Jun 2017, 23:32 Life's too short to drive so slowly so as to achieve Economy Run mpg figures!
That's why I run and cycle.. Gives a great Endorphin high... It's called 'runner's high' and that's exactly what it is...van ordinaire wrote: 13 Jun 2017, 13:00 I do miss a lot but arrive in a similar state as you (probably still high on adrenaline!).
van ordinaire wrote: 13 Jun 2017, 13:00 "Drivin' down the road at too many miles an hour" That's one of my faults, obviously having been unduly influenced by Status Quo at an impressionable age!
