VIN & RP car spec questions...
My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally
x 1288
Contact:
Re: VIN & RP car spec questions...
Post by Stickyfinger »
I have a spare alarm klaxon here from a Mk1 car....just took it off the other day....
Activa, the Moose Rider
3x C5x7 Steering racks and counting
ekjdm14
Lexia Available: Yes
My Cars: '95 Xantia 1.9D automatic - 109k one of two remaining
'03 206 GTi180 - 97k in pieces being brought back up to snuff
'03 206 1.9TD - home-built veg-fuelled B-road bruiser
'99 306 SE 2.0i cabriolet - 92k awaiting service work ready for next summer
'97 306 XS 1.6i 3 door, Bianca White, from dead 12 years & seized solid to road legal in 7 days
x 212
Post by ekjdm14 »
Working/good battery? I'm hoping I'll be able to repair the one that's fitted given it's likely the internal battery and maybe a dry joint or two IMO that's stopped it working but if that comes to nought I'll bear that in mind. Hopefully get a chance to look sometime this week, having successfully got the interior swapped today. Where, pray tell, do they hide said siren? Guessing in the scuttle area close to the key, from where the noise seemed to emanate.
'95 Xantia LX 1.9D-auto, Black, 109k
'03 206 GTi180 94k in surgery
'03 206 1.1S XUD9TE/veg project :mrgreen:
'99 306 2.0SE cabriolet 95k summer toy
'97 306 XS 1.6i 99k sat 12 years, fixed in 7 days, 150mile maiden voyage :rofl2:
les
Locked user account
My Cars:
Post by les »
Dan,door cards,carpet, steering wheel are from a N plate VSX. Leather seats unsure( exclusive maybe ) instrument cluster from same VSX . A mirror was damaged by drunken idiots over last Christmas (o/s) I was given a replacement but it differed from the n/s in that it had the removable plastic backs that are normally colour coded.so I obtained a n/s to match. White was badged as a Desire hope that helps, also think the siren is located behind n/s inner wing. Les
ekjdm14
x 212
Post by ekjdm14 »
Ah, that's the remaining info really as these & the VSX wheels were the only bits not original to the spec sheet :) They're now sat pretty in Black & the velour is sat in the garage while I wait for the left floorpan & insulation to dry out. May be that the scuttle crack is the root cause of the airbag fault since it's corroded a connector with some of the pre-tensioner wiring in, actually just posted my plans for that in the blog area. Basically seal with tape to preserve the car for now & either re-seal/repair the scuttle or rescue one from the scrap yard if I can remove it in one piece.
Cheers.
Post Reply
