OK, so the new hose arrived today and it's fitted.
Turned ignition and the pump (under the tank , yes?) Is whirring away but the suspension isn't going anywhere. I believe there are bleed points on the system, am I right ? Anyone got a location on these assuming that could be my issue. Cheers
Sent from my SM-N910F using Tapatalk
2006 c5 lds capacity?
- Lexia Available: Yes
- My Cars: '95 Xantia 1.9D automatic - 109k one of two remaining
'03 206 GTi180 - 97k in pieces being brought back up to snuff
'03 206 1.9TD - home-built veg-fuelled B-road bruiser
'99 306 SE 2.0i cabriolet - 92k awaiting service work ready for next summer
'97 306 XS 1.6i 3 door, Bianca White, from dead 12 years & seized solid to road legal in 7 days - x 212
Re: 2006 c5 lds capacity?
myglaren wrote:Should be no need to run the engine. Pump should run to adjust height anyway - sitting on the rear bumper should be enough.
But - and a big but - priming should be done or at least attempted with the pump fuse pulled as running it dry could well damage it.
Have you primed the system/know fluid is reaching the pump?
'95 Xantia LX 1.9D-auto, Black, 109k
'03 206 GTi180 94k in surgery
'03 206 1.1S XUD9TE/veg project
'99 306 2.0SE cabriolet 95k summer toy
'97 306 XS 1.6i 99k sat 12 years, fixed in 7 days, 150mile maiden voyage
- My Cars: 2022 Trafic work van
2017 Kadjar
Previous
06 C5 1.6 HDI
00 Xantia 1.8
00 Clio 1.2
98 Xantia Activa (briefly)
97 Partner van
97 Safrane 2.5 Auto
94 Safrane 2.0
Re: RE: Re: 2006 c5 lds capacity?
I gave a few blows in to the tank as described before. I'll give it another go in a bit and see.ekjdm14 wrote:myglaren wrote:Should be no need to run the engine. Pump should run to adjust height anyway - sitting on the rear bumper should be enough.
Sent from my SM-T580 using Tapatalk
- Donor 2023
- My Cars: Xantia Activa - one day I`ll own her again! Also miss my `old` 405 GLx4
2005 C5 3 Litre V6 Exclusive in Mauritius Blue and my 1997 Xantia Exclusive V6 - x 23
don't forget to turn the steering wheel as well with the engine running to fill the power steering with the lds
Simon
2017 Kadjar
Previous
06 C5 1.6 HDI
00 Xantia 1.8
00 Clio 1.2
97 Partner van
97 Safrane 2.5 Auto
94 Safrane 2.0
We have liftoff just needed more lung power . Just need to get the level right now.
Did the power steering first thing. It's something that's always at the front of my thoughts having had issues with volvo power steering a couple if times. You never forget the sound of a power steering pump running dry
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 2991
So citroenxm's trick worked then? While I had little doubt it worked for him, the fact others can do it makes it far more useful.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
2017 Kadjar
Previous
06 C5 1.6 HDI
00 Xantia 1.8
00 Clio 1.2
97 Partner van
97 Safrane 2.5 Auto
94 Safrane 2.0
Yeah. Definitely brought it to life.
2017 Kadjar
Previous
06 C5 1.6 HDI
00 Xantia 1.8
00 Clio 1.2
97 Partner van
97 Safrane 2.5 Auto
94 Safrane 2.0
Not convinced all is well, it doesn't seem to be dropping right down and not as quick as before. I wonder have I put the hose on slightly coverign the hole in the sturt and it's blocking the fluid from returning properly. Would that cause the issue?
2017 Kadjar
Previous
06 C5 1.6 HDI
00 Xantia 1.8
00 Clio 1.2
97 Partner van
97 Safrane 2.5 Auto
94 Safrane 2.0
So I went out to sort some stuff for work tomorrow and as said, it has been a stinker since I got it, but prior to the fluid loss it would rise once it was unlocked. Since getting it running again the other day I've been starting it when I've unlocked it but today I noticed the pump ran for a bit (30 + seconds ish) but the back never rose. So it's not rising if I don't start it. Could it be air in the system or some such? Does it need to be bled?
- Donor 2023
- x 2991
I wonder if a Citrobics session or two might help here? What you could try doing is to take the suspension to full high service height, wait for a couple of minutes (to allow things to settle down), then turn the steering from lock to lock a few times, drop her to full low service height, wait for a couple of minutes again, steering from lock to lock again, and then repeat a few times. That can help the LDS circulate, and help move any air to the reservoir.
Once you have done a Citrobics session (say, 20 minutes worth) I would then (after bottoming her out) check the LDS level, to see if the level has dropped. If it has (and you cannot see any signs of a leak) it would suggest some air has been purged out.
Citrobics can also help to keep various things moving smoothly, and is normally something green blooded Citroens benefit from.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
