Still driving quite nicely although I raised the drivers seat yesterday as I was sitting a bit low. Now I have an airbag fault, I dare say I've tweaked a connector under the seat.
Sent from my Wileyfox Swift using Tapatalk
C5, The Good, the Bad and the Ugly
- Donor 2016
- x 77
- Donor 2016
- x 77
Re: C5, The Good, the Bad and the Ugly
Interesting, in the rain today both mirrors folded and unfolded perfectly. As soon as it started to dry up this afternoon the left one started sticking again. I think something is tight, further investigation called for.
Sent from my Nexus 7 using Tapatalk
- x 2251
It sounds like the water is making the circuit as you say, so a clean up of any contacts sounds like a good place to start. It's possible the door modules might be exposed to water getting in through the windows / window guides / doors, but likely the windows guides nearest the front of the dash, as I think the door modules are just underneath there IIRC. This is another reason to squirt silicon grease down the window channels twice a year to help repel water off the window regulator wires and the like. They get water on and rust, but a good coat (not WD 40 Lube) will help protect and coat them.
- Donor 2020
- x 204
I think it's more of a tight pivot/catching trim issue Marc, that seems to be what the above post suggested anyway (possibly ties in with my damage/vandal theory about the plugs being left off too). Sound advice nonetheless, water and electronics are never a good combination even where they're intended to mix (VW coolant level sensors for one) and anything that lessens the chance of the two becoming intimate is A Good Thing.
- x 2251
Just odd that it's intermittent with the rain though - and assuming the door was still shut when it decided to work. The wires did seem a little tight though from the pics.
I had to have the window regulator replaced when the driver's window failed (at the multi-storey exit barrier no less when the wire decided to snap). Citroen replaced the complete unit, motor and all - a tad about £500
for the job and since then, all window channels get a regular lube down the guides with silicon now
- Donor 2020
- x 204
Phew, that's a pretty penny. Cannot blame you in the least for keeping on top of any corrosion issues after that! I thought it was just Renault that were the window-spitters!
- Donor 2016
- x 77
Just took Wifey up the library and the mirrors were fine. Let's hope they stay that way.
- Donor 2020
- x 204
Good stuff, had it been raining again/any residual moisture in the pivot?
My thinking is the water could have been acting as a temporary lubricant on rubbing plastics or a dry pivot. Or maybe it was just lack of use that's now being rectified by you? Let's hope that's what it is:)
- Donor 2016
- x 77
Yes I agree, dry and rubbing somewhere. The rain's gone and it's sticking again. I'll check further this week. I need to get Lexia on it now to sort the airbag issue.
- Donor 2016
- x 77
Still driving ok. Getting approx 25-26mpg around town with lots of stop starts and slow traffic. If I drive to my daughter's about 2 miles away on quiet-ish estate roads the mpg creeps up towards 27. I'm sure on a good run that will be high 30's 40's. Apart from the airbag fault and sticky mirror it's ok and nice to drive.
- x 1510
You drive two miles Dave? I'm shocked...
That's in nice gentle stroll territory and never warrants a drive surely?
Think of all the diesel you would save by walking those small distances
- Donor 2016
- x 77
Oh yes I would walk that easily Jim. But there is no way the wife would, she's shocked that I don't drive to the top of the road for the shops. We popped 2 miles into town today and she moaned just walking round the shops! I keep telling her to buy a mobility scooter.
- x 1510
Ahh right, understood Dave
We won't be seeing her at a parkrun any time soon then!
- Donor 2016
- x 77
Err no Jim. I'm hoping to get out into the sticks soon for some walking as the forecast is picking up.
- Donor 2017
- x 240
The interior lights in the Caddy don't go out when it's damp - don't you just love old electronics (that were too clever for their own good when they were new).
Can I get a Twizzle, sorree, (Renault) Twizi clasified as a mobility scooter?
