Guide to Replacing the NG4 Navidrive 3D Hard Drive with a CF Card
This unit is the NG4 system, made by Harman Becker.
Main Features: DVD, Voice Commands, HighRes Display, 3D Mapping, Bluetooth Hands Free, Independent Phone with MDS Module, SD Card, USB, Jukebox.
Moderator: GiveMeABreak
Post Reply
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow
x 5708
Re: Guide to Replacing the NG4 Navidrive 3D Hard Drive with a CF Card
Post by GiveMeABreak »
Make sure you have the latest firmware and a good uncorrupted copy and a correctly formatted USB key with nothing else on it apart from the expanded Firmware files.
Have a read back here for another member who had the same issue:
viewtopic.php?p=603054#p603054
Read the next 10 or so post from there - he fixed it in the end.
Karlitos_205
My Cars: Citroen C5 2.0HDi Exclusive CAS
Post by Karlitos_205 »
GiveMeABreak wrote: 08 Dec 2021, 21:34 Make sure you have the latest firmware and a good uncorrupted copy and a correctly formatted USB key with nothing else on it apart from the expanded Firmware files.
Thanks for answering but I have read that and the hard drive is checked and OK.
That is why I would need a backup copy to copy it to the hard disk from the PC and see if this is how the NG4 works.
Thank you very much again.
C15 Romahome White
CX 20 Polar White
x 5708
I doubt you'll get any offers with this given that anybody's disk image (if they have one) is going to be 40Gb!
Karlitos_205
GiveMeABreak wrote: 09 Dec 2021, 06:06 I doubt you'll get any offers with this given that anybody's disk image (if they have one) is going to be 40Gb!
The truth is that if it is great what I ask hehehe
Could you tell me at least the size of each partition to do it from the PC?
Thank you!
C15 Romahome White
CX 20 Polar White
x 5708
I don't think this will work.
When the system is booted from the firmware, it will automatically create the correct partitions for you and then install the operating system files. Your main issue is double checking you have a valid uncorrupted Firmware file and that the media / Compact Flash card and adapter are all working correctly. Without this nothing will work. Of course, keep trying the update and regardless of what you think - download a fresh copy of the firmware and use a different USB stick to store it on and keep the engine running during the update which can take about 40 minutes.
While performing this procedure, don't drive the car and don't press any buttons, open doors, or use any equipment. Doing this can send signals along the data network that can interfere or interrupt the update process.
Karlitos_205
GiveMeABreak wrote: 09 Dec 2021, 13:01 I don't think this will work.
Could you pass me the firmware in case mine is damaged? Thanks
C15 Romahome White
CX 20 Polar White
x 5708
PM Sent
Karlitos_205
Thanks again.
I have reinstalled the update and I get error 0x3019 after restarting at 67%
Kaktus14
My Cars: Peugeot 5008
Post by Kaktus14 »
marioi1983 wrote: 11 Dec 2020, 22:30 I saw a couple of videos of some guys installing the fw but they can boot and see the peugeot logo. And they have the option to choose if they want to install it.
I only have that stuck menu. But i will test the usb key tomorrow.
If i change the HDD and install the new fw, this will only format and install the fw or will delete other stuff like GPS maps etc..?
Did you fixed the issue?
I have 2012 Peugeot 5008 and this morning when turning on the car I got the same "System check in progress - Please wait and do not switch off the engine for 25 min" on my screen and quick search on internet didnt proved helpfull that there is a quick fix for this.
@GiveMeaBreak - can you send me latest firmware so I can try updating that even tho I doubt it will help.
Many thanks
Kaktus14
Post by Kaktus14 »
Thanks Marc for link.
Yes I also feel that hard drive is gone, but now I have one more thing I m not sure about. I will get either CF or same Toshiba hard drive but if my current one is dead and I cant copy data and OS from it, how will I install OS to new one or CF?
As firmware is much smaller then 30gb that OS currently takes.
Does anybody has experience with configuring OS from start without data from existing HDD?
C15 Romahome White
CX 20 Polar White
x 5708
Ok, so the firmware I gave you creates the partitions automatically. Once you have the new CF Card installed correctly, inserting the firmware on USB will re-crate the partitions and install the Operating system for you.
You won't easily be able to get an automotive grade 40Gb hard drive that meets the PATA IDE standards today to replace the one in the unit. That's why a lot of us have replaced it with a CF Card, because the ATA command set used by CF Cards is the same. Don't try and put a SATA SSD drive in place - it will grind to a halt as the operating system does not support SATA, nor the TRIM function. Keep it simple for compatibility.
It's all detailed in the first post of this thread.
Kaktus14
Post by Kaktus14 »
GiveMeABreak wrote: 01 Feb 2022, 17:02 Ok, so the firmware I gave you creates the partitions automatically. Once you have the new CF Card installed correctly, inserting the firmware on USB will re-crate the partitions and install the Operating system for you.
Thanks.
I read first post and I ordered now CF card, IDE to USB adapter and USB CF card reader so when everything arrives in 10 days or so I will give it a try and see if hard drive was cause of this message.
Car is still driving, I can live without music only thing that I miss currently are parking sensors which also dont work without infotaiment system.
C15 Romahome White
CX 20 Polar White
x 5708
Ok, well just a tip - I would go straight to installing the new CF Card and don't bother cloning the original Hard Drive, as it can be an issue if there is corruption already. Once you are happy you have the drive settings correct, then just go straight to installing the firmware. As I said, it will put the operating system on for you after creating all the partitions of the correct sizes.
It can take maybe 2 or 3 attempts for the firmware to go on, but don't panic.
Once you have it setup with your preferred options, you can then consider reinstalling things like the maps.
Another tip. I highly recommend using the front SD Card port for playing MP3 music files instead of using the Jukebox. I used a 32Gb SD card and that had thousands of music files on.
Schlitti86
My Cars: Citroen C5 III
Post by Schlitti86 »
Hi there,
it got me too now. After driving for several days with the error message: "System check in progress", I dared to replace the hard drive. Unfortunately, I can't access the hard drive with the computer.
It is displayed, but there is no data on it.
As I understand it correctly now, I first have to copy the operating system to the new disk before I carry out an update via the SD card.
What can I do to get the operating system data?
Many greetings,
C15 Romahome White
CX 20 Polar White
x 5708
1) This sounds all wrong to me - you don't use any SD card to update this system. The firmware must be used from the USB port to update the system.
2) You can't read the data in Windows - it is not Windows based. It uses an QNX RTOS, an automotive derivative of Unix.
3) All you need to do assuming you have the new hard disk in place or a CF Card instead, is to restart the system with the latest firmware extracted to a USB flash drive key and have the USB drive inserted in the centre armrest USB socket.
Post Reply
