Two thoughts...
- Does the car have volumetric (cabin) movement detection? This can misbehave, or be affected by thermal air movement. Can be switched off on some models.
- Is there a proper alarm reset procedure, after battery disconnection?
C5 Alarm keeps going off after battery disconnection
- white exec
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5712
Re: C5 Alarm keeps going off after battery disconnection
1) Yes - Perimetric and Volumetric as standard.
2) No, just the standard Battery Connect / Reconnect Procedure.
- white exec
Worth trying switching the volumetric off, as a test?
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 3007
I recall, in the past, having to replace the 'microphone' ultrasonic sensor on my Xantia, as it was not working properly and causing the alarm to go off for no good reason. The new 'microphone' sorted this out. I also recall that Mandrake (Simon) had a similar issue with one of his Xantias, and he was able to replace the microphone and fix the problem. While I am aware that the OP has a C5, it may be possible it has developed a similar fault.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
That's why Chris already suggested deactivating the volumetric (there is a button specifically for this) to test it.
- My Cars: Citroen c4 grand picasso
I moved the shunt today and it's worked, can't believe it's something so simple after all this time, thank youMark Clayton wrote: ↑29 Nov 2019, 11:43 Hi. The RAC man simply put the SHUNT fuse ( in the glove box site) ¼" to the left and as a result the car was in dealership mode. If the fuse were moved to the right, all would be back to normal. No dealership extortionate charges!
- New User
- My Cars: Citroen C5, 2008, 2.0Hdi 136/101kw. Diesel, manual.
Gentelemen, i had the same isssue for 3 year. i could lock my C5 only with a key because each time if i will lock with remote control it will go off after 3-5mins. it was impossible to is use it at all. I when to check SHUNT fuse i move to right side and final all is OK. I would like thank you all of you. Stay save and healthy.
Regards
V
Regards
V
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
@ Viko: You'll probably find you need a new alarm module - Once the independent internal battery fails, it's the same as if somebody tried to cut the supply - it triggers the alarm. Although they last a long time, once they fail they will constantly go off as they cannot hold a charge for very long.
I had the same issue on the C3. Locking with the key does not arm the alarm - only with the remote. I replaced the alarm module (a simple job) and everything is fine.
