See my advice on a quick compression check above.ekjdm14 wrote:Just a thought, have you checked the valve clearances. Just remembered a gem of info that Jim told me, the clearances are tightest when the engine is fully cold so if they're tight it'll make cold starting near impossible due to low compression.
Xantia 1.9td occasional hard to start
- white exec
Re: Xantia 1.9td occasional hard to start
- white exec
SFAIK, a leaky (or even unconnected) injector leak-off pipe simply results in annoying and smelly fuel spillage, and doesn't affect fuel being fed under pressure to the injectors, nor engine starting or running. Fuel leak-off pipes just lead back to the fuel tank, via the return pipe.
- demag
- My Cars: "H" Citroen Bx Tgs Automatic.
2006 Toyota Prius T4 Gen 2. - x 102
Although "non serviceable" I opened up the glow plug relay on my XM and found the contact points badly pitted. I used the wet 'n dry method to clean them up. I also found one of the heavy duty cables nearly rotted through by the connector so I remade ALL the connections.
Sent from my Wileyfox Swift using Tapatalk
Dave
- white exec
Exactly the same here: pitted contacts and heat-damaged cable terminations.
- My Cars: Citroens since 1990, BX Diesel, GTI, TZD with 1.9 TD running extra boost before it was fashionable!, ZX Volcane TD, S2 Xantia break 1.9TD, Xantia HDI 110, currently zipping about in a C2 Diesel. C2 died from the dreaded worm, C3 Picasso HDI Exclusive, the adventure continues.
- x 31
Any splits in the leakoff pipes will cause non or poor starting with Bosch pumped engines, for some reason Lucas pumped ones behave differently?
- Donor 2023
- Lexia Available: Yes
- My Cars: 2008 C5 Exclusive Tourer
1993 Xantia 1.9 TD VSX Mk1 Sinker A.K.A Slugmobile 13'
'Old Katy'
previous convictions: totaling 52litres of LHM in one go:
1968 ID19B 'Old Polly' Stellar white
1993 Xantia 1.9 TD SX Mk1 Sinker Silver
1992 XM 2.0 SEi Turbo Manual Anthracite Grey
1982 CX 20 Pallas 'Old Goldy'
1993 XM 2.1 SD Auto Light blue
1993 Xantia 1.9 TD SX Mk1 Sinker light Blue
1982 BX 16 TRS 'Cyril' Vallelunga Red
1995 Xantia 1.9 D SX Auto Dark green
1977 CX 2400 Pallas C-Matic 'Aphrodite' Regatta Blue
1982 GSA Pallas SE Silver Pearl
1980 CX 2000 Reflex Vallelunga Red
1978 CX 2400 Pallas C-Matic 'Prometheus' Midnight blue
1984 BX 14E 'Cecil the slugmobile' Maroon
1987 Fiat Panda 'the mighty panda' - x 98
Well it started on the button this morning! I'm still going to renew the glow plug cables as a precaution.
Graeme M
- white exec
Has to be cabling or relay, I'd guess, Graeme. If it was dodgy GPs, starting would still be consistently ropey.
- falling-out-with-my-car
- My Cars: Citroen C5 Aircross 8 speed Automatic, Flair Model with far to many toys and nice comfy armchair like leather seats. ha ha Ive just had a conversation with the car. setting everything up verbally
- x 24
If its an s2 xantia the glow plugs run on for a while when started as long as you don't touch the throttle. My 1998 xant didn't like starting with perished leak off pipes.
Sent from my GoFone_GF50X using Tapatalk
- Donor 2023
'Old Katy'
Thanks, well it's still starting on the button! It started after a day's rest this evening on what sounded like half crank of the engine so it's pretty good now. New MOT just got as well!
Graeme M
