xantia hdi starter motor
My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
C5, C5, Xantia, BX, GS, Visa.
R4, R11TXE, R14, R30TX
x 4917
Re: xantia hdi starter motor
Post by myglaren »
I meant on a rolling road or similar James - even on a real MOT.
van ordinaire
(Donor 2017)
Location: Live & work in London but weekend in Devon (or do I now live in Torbay & work in London?)
My Cars: Citroens:-
'81 2CV Club (quietly sleeping in a parallel universe)
'05 (yes, really) C15
'97 Xantia Exclusive estate
others:-
'96 Jeep Cherokee Limited - the "donor"
'99 Jeep Cherokee Orvis - the green one
'97 Jeep Cherokee Limited - the red one
'99 Cadillac Seville STS
'96 Cadillac Eldorado ETC
& numerous what might be described as abandoned projects!
x 405
Post by van ordinaire »
KennyW wrote:Thanks Ted,
I'm having more of these moments !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Chris, I would check the 'thingy' as they don't like water or muck as well.
Kenny
Jeep ones just have to put up with it! :lol: but THEY do suffer from Neutral Safety Switches, which can produce exactly those symptoms. Just a thought, no harm in a little X-polination of ideas :wink:
Citroens:-
'81 2CV Club :cry:
'05 C15 :!:
others:-
Jeep XJ Cherokees x 3 :?
'99 Cadillac STS :|
c.morewood
Donor 2023
My Cars: '00 Xantia 110 bhp Hdi SX Estate 65K "W"
'99 Xantia 110 bhp Hdi SX Estate 310K SORN "V"
'98 Xantia 1.9TD SX Estate 150K Sold "T"
x 47
Post by c.morewood »
I thought I'd publish the end result of the "starter motor failure". Turns out it wasn't the starter motor at all. It was the ignition switch. It failed again a couple of days before I went on holiday last month. Left it with the garage whilst I was away, expecting a new starter motor. Instead I have a rocker switch attached to the steering cover beside the ignition switch. I have to turn the key and hold the switch till she starts. I'm now wondering whether to leave as is or replace with another ignition switch? Presumably its easy enough to get the barrel out of the switch and to put it into another?
Tesla Model 3 LR DM AWD Blue White
'00 Xant 110HdiSX Est 83K "W"
'99 Xant 110HdiSX Est 320K "V"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'85 BMW K100RT 330K Garaged 26yrs '80 Honda CB250 twin Superdream
KennyW
My Cars: Current Citroen's
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
Xantia 2.0 90hp estate
Xantia 1.9 TD estate
x 132
Post by KennyW »
Removing the ignition barrel is easy Chris. If I remember correctly ignition barrel switch has a front and back which separates.
If you have access to a 2nd ignition switch the back parts and reassemble and problem solved.
Kenny
C5 x7 2.0 HDi 160 hp Estate exclusive, the newbie
C3 1.4 petrol (SWMBO)
c.morewood
Donor 2023
x 47
Thanks Kenny
'94 Fiat TipoTd 40K
Timmo
(Donor 2022)
My Cars: 58 partner teepee outdoor hdi.
58 C2 Code in black! Fun!
x 168
Contact:
Post by Timmo »
Is it the ignition switch that has failed or simply the feed wires? If the latter, relay mod in the circuit will most likely fix, or you could replace the rocker switch with a push button starter? (essentially the same as the installed switch)
'58 C2 Code
'58 partner teepee outdoor
My Cars: Bluebell the AX, Polly the C3 Picasso, Pix the Nissan Pixo, Propel the duathlon bike, TCR Pro the road bike and Fuji the TT bike...
x 6176
Contact:
Post by CitroJim »
Timmo wrote: 26 Sep 2017, 07:34 Is it the ignition switch that has failed or simply the feed wires? If the latter, relay mod in the circuit will most likely fix, or you could replace the rocker switch with a push button starter? (essentially the same as the installed switch)
Relay mod as per the V6 will work a treat on the HDi
KennyW
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
x 132
Post by KennyW »
I thought MK2's had the relay mod done as standard.
Kenny
x 6176
Contact:
Post by CitroJim »
KennyW wrote: 26 Sep 2017, 09:25 I thought MK2's had the relay mod done as standard.
Kenny
Only for the heater blower Kenny, not the starter motor...
c.morewood
Donor 2023
x 47
More details please Jim. Do you have a link to the page please? I tried a search but just came up with this thread.
'94 Fiat TipoTd 40K
x 6176
Contact:
Post by CitroJim »
c.morewood wrote: 27 Sep 2017, 22:17 More details please Jim. Do you have a link to the page please? I tried a search but just came up with this thread.
It's buried deeply in my blog I think Chris...
But meanwhile, this thread will give the bare details... Look at my post in in a little way down ;)
https://www.frenchcarforum.co.uk/forum/ ... ay#p300584
Hope that helps...
c.morewood
Donor 2023
x 47
Thankyou Jim
'94 Fiat TipoTd 40K
x 6176
Contact:
Post by CitroJim »
Chris, if you need any further details or how to fit the relay, just give me a shout...
KennyW
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
x 132
Post by KennyW »
How many relay mods are there Jim ??????????
Kenny
elma
My Cars: Undisclosed
x 287
Post by elma »
On a MK1,
Starter motor
Headlamps
Fan motor.
Not sure if the MK2 needs the headlamp one or not.
Post Reply
