To remove the pump and dearmour is not hard but a methodical approach and time you will have success.
It maybe worth checking there is a supply going to the stop solenoid as I had broken wire there.
Kenny
Help save my Xantia! AKA The immobiliser has made it break down.
- KennyW
- My Cars: Current Citroen's
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
Xantia 2.0 90hp estate
Xantia 1.9 TD estate - x 132
Re: Help save my Xantia! AKA The immobiliser has made it break down.
C5 x7 2.0 HDi 160 hp Estate exclusive, the newbie
C3 1.4 petrol (SWMBO)
- My Cars: '95 Xantia 1.9D automatic - 118k one of two? remaining
'97 306 1.6 XS, 24k, The ex-Haynes "Max Power" display car. Bought after being written off & stripped, now being rebuilt without the wide body
'96 ZX 1.9TD SX, 81k new resurrection project saved from the scrapper - x 216
Our ZX was bought as a non-runner with just the problem described above, although on ours the wire was broken as it came out of the actual solenoid. I actually cut away the pump armour in-situ to replace that, although it may be harder/not possible on a Bosch pump as ours was Lucas. Possibly worth a try though if you have a 4" grinder & either a dremel or cold chisel for the tight spots...
'97 306 XS 1.6i, Blaze Yellow, 24k
'96 ZX SX 1.9TD rolling shell, White, 81k
- CitroJim
- x 6204
- Contact:
Very true Kenny and a good excuse to do the cambelt and water-pump at the same timeKennyW wrote:To remove the pump and dearmour is not hard but a methodical approach and time you will have success.
MFH, If I can help with wiring diagrams then please let me know and I'll post them...
