C5 serious suspension fault
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5712
Re: C5 serious suspension fault
Yep got that, has to be your choice though I'd still stick to the original Total stuff for my car.
- Stickyfinger
- My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally - x 1289
- Contact:
Me as well, at the price of LDS I see no reason to look beyond the use anything other that that (or the DA)
Activa, the Moose Rider
3x C5x7 Steering racks and counting
- Paul-R
- Donor 2023
- Lexia Available: Yes
- My Cars: 2015 1.6 Blue HDi 120 Peugeot 308 Active SW
2013 2.0 HDi 163 C5 Exclusive Tourer
2003 2.0 HDi 110 C5 Exclusive Estate (Gone)
2001 2.0 HDi 90 Xsara Estate (Gone) - x 1377
^^^ Plus 1 for that. Nothing written on the back would convince me to use it. It covers just too many specifications for my liking.
- Donor 2023
- My Cars: Xantia Activa - one day I`ll own her again! Also miss my `old` 405 GLx4
2005 C5 3 Litre V6 Exclusive in Mauritius Blue and my 1997 Xantia Exclusive V6 - x 24
well - it fixed the suspension for its mot , and once passed it will have a flush and new lovely LDS (its black in there!)
but it failed on rear brakes little or no effort and front parking brake little or no effort
bugger
bugger
Simon
- Paul-R
- Donor 2023
Did they give you any idea of what might be wrong with the brakes? My first thought is that the discs are rusted and have too little contact area. A quick visual inspection would quickly prove or disprove that conjecture.
- Donor 2023
I was watching the meter - very little braking force when he pushed them.
and both front and rear disks look rusty
I have a feeling , since I was laid up December 2015 , the brakes might be seizing
Simon
- Stickyfinger
AX, little Daffodil
- Contact:
Again, MOT man fails to understand the rear brakes of a Citroen....dump a load of weight in the back next time to load the rear. 6 bags of sand or some concrete slabs next time.
That or the classic caliper angle/corrosion. Inspect the pads (look) are they worn at an angle ?
- Donor 2023
actually I think he knows them quite well , as he removed the LDS cap before I even mentioned it....
parking brake worked on nearside , just not offside.
I *think* I`ll take the wheels off tomorrow and check , but when I had the front NS tyre done (for its ticket) , the caliper looked rusty , as if it had been stood for a while.
Simon
I freed off my parking brake by wiggling the pivot and judicious use of plus gas. It was one side as well. I hope your rear brakes and discs are not like mine were. PO had filed the heads of caliper bolts to stop wheel snagging. Seized bolts...............with no heads
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
- Stickyfinger
AX, little Daffodil
- Contact:
Front Caliper bolts ?.....a "crack sound".....they often do.
- Donor 2023
rear calliper bolts - liberal use of penetrating oil and as they turn they are cracking.... not breaking but a crack as they go. very slowly!
Simon
- Stickyfinger
AX, little Daffodil
- Contact:
Sounds normal to me......the threads will be dry. I will often do a half turn back to help clear the threads on such bolts when they are very dry.
- Donor 2023
moving a lot better now with the oil on them - got 2 days of presentations next so better chance after friday
Simon
