C5 serious suspension fault
- Donor 2023
- My Cars: Xantia Activa - one day I`ll own her again! Also miss my `old` 405 GLx4
2005 C5 3 Litre V6 Exclusive in Mauritius Blue and my 1997 Xantia Exclusive V6 - x 24
Re: C5 serious suspension fault
when its set to on the floor low - should I be able to see any LDS in the tank filter?
Simon
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5741
The car should be on the lowest setting and left for a few minutes to ensure as much of the system is depressurised as possible, then check that the LDS levels should be between the A and B marks:
- Donor 2023
hmmm it doesn't even cover the bottom of the basket
would too low lds throw up and error?
Simon
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
No errors for low fluid levels, but you may get a general suspension fault if it becomes too low.
- Donor 2023
such as a serious suspension fault with errors from both height correctors? ECP have some for £8 this weekend for 1 litre
the bottom of the basket has a thin layer now
Simon
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
I can't tell what C5 you have Simon from your profile. On the X7 there is a joint power steering / suspension fluid level warning, but can't remember it this is also on the Mark II. I'll see if I can find out. The fact that your error went awa y when you disconnected and reattached the ECU plug suggests that your car might benefit from a BSI reset. If you are going to do this, leave the battery terminal off for a good 10 mins before reconnecting it and following the rest of the procedure. This will help to clear down the ECUs properly.
- Donor 2023
Its an 02 reg (RPO 9250) mk 1 C5 2.2 HDi estate
and it took just over 500ml of LDS - went in green , certainly not green now after some citerobics!
Simon
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
GREEN???? I hope not! It should be an orangey colour. Please don't say you have put LHM in instead of LDS?
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
What is the make and what is the specification? Do you have a picture?
- Donor 2023
rated to PSA S712710
http://www.eurocarparts.com/ecp/p/car-a ... &0&cc5_871
bottle says citroen LDS on the back!
Simon
- Donor 2023
given what I could see was / is black - I think a full system change might be needed and soon (odds on it hasn't been done! )
came belt done 7/7/09 in the service book though, so change soon as well?
Simon
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Personally I would only use the recommended fluid. In this case the Total Fluide DA which has replaced LDS. There are 2 litres here for £17.99, the same price per litre as that other stuff!
https://www.amazon.co.uk/Total-Fluide-D ... 1RMDW38M9H
- Paul-R
- Donor 2023
- Lexia Available: Yes
- My Cars: 2015 1.6 Blue HDi 120 Peugeot 308 Active SW
2013 2.0 HDi 163 C5 Exclusive Tourer
2003 2.0 HDi 110 C5 Exclusive Estate (Gone)
2001 2.0 HDi 90 Xsara Estate (Gone) - x 1379
Just the name of the product - MT75 - would worry me as it sort of implies that it's SAE 75. I would dearly love to look at the back of the bottle to see if there's any more technical information there. The lack of a technical PDF or specification page also worries me.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
I've looked at the picture and there is nothing there apart from saying it meets the PSA spec. I still wouldn't use it due to the lack of information. I've heard it is made by Shell and is also recommended by the RAC shop, but I wouldn't necessarily say that means anything either as they are probably on kick backs! Can't seem to find the specs, so a no go for me.
