Electrican help please? Citroen C4GP ABS wiring mare (fixed)
- myglaren
- My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
C5, C5, Xantia, BX, GS, Visa.
R4, R11TXE, R14, R30TX - x 4922
Re: Electrican help please? Citroen C4GP ABS wiring mare (fixed)
Could you post your full VIN. It will be hidden except to forum staff.
Reason: Silly mistake corrected. I blame the keyboard.
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 3008
Steve, you are NEVER hidden on this forum!
How do you know when I go invisible?
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
D2J wrote: ↑06 Aug 2019, 16:36 Resurrecting this thread as it seems similar.
I have acquired a C4GP with some faults showing: ABS ESR Handbrake, gearbox.
Lexia is telling me that the Front Left sensor is showing 255kph.
On further investigation I find that some kind soul has been around this before and cut the ABS lead! It looks as though there has also been some attempted investigation around the fusebox and I also see that it's had previous invoice for clearing out the scuttle drain.
All this is pointing me towards a fault in the loom at the back of the fusebox, but it seems like a good idea to first check by doing a similar thing to pauldoubleyou and running a lead from the ABS plug to the sensor to see if this clears the fault.
I would be grateful if someone could point me towards the correct wires to take off from.
Many thanks, Brian
The car's code is 11831FV if that's any help
Not really, we need the VIN if you want electrical diagrams. Pop it up here and please be specific as to what you want - is it the wiring from the ABS sensors to the ESP ECU you need?
- My Cars: Pug 305, 405, 306
Ren Scenic I II
Thank you Marc,
Yes, the wiring from the sensors to whatever ECU they go to which I am assuming is the ESP from your reply.
Brian
Brian
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Ok, so you have the C4 PICASSO ESTATE - LEISURE 1.6 HDi 110 particle emission filter (DV6TED4) piloted manual gearbox 6.
Here's the diagram
7800 is the ABS / ESP ECU
7810: front LH ESP sensor
7815: front RH ESP sensor
7820: rear LH ESP sensor
7825: rear RH ESP sensor
The ABS sensor wiring goes into the 34 pin Black socket of the ESP ECU. The pins are parked on the diagram and also on the socket on the ESP connector.
An example of the wiring sown for the 7810 ABS sensor is:
7002U: Pin 1 - Left-hand front wheel speed signal reference
7001U: Pin 2 - Left-hand front wheel speed signal
The other sensors will be the same - the speed signal reference and the actual speed signal.
If you need other components shown, there is a reference on our Wiki here that has many of them, but if not shout:
https://frenchcarforum.co.uk/wiki/Elect ... ring_Codes
Here's the diagram
Hi, can you take me the diagram of my car? VIN VF7**************[VIN obfuscated, can be read by forum staff]
GiveMeABreak wrote: ↑06 Aug 2019, 19:05 Ok, so you have the C4 PICASSO ESTATE - LEISURE 1.6 HDi 110 particle emission filter (DV6TED4) piloted manual gearbox 6.
Here's the diagram
hello,
I really need diagram of mine car, can you help me please?
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
@ alexszcz: What do you need - the ABS / ESP system?
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
It's a single system ABS & ESP. Here you go:
Note: This is for the Picasso C1.6 HDI 115 (DV6C) piloted manual gearbox 6 (With stop and start) Specifically
Hi. My C4GP has also started showing these ABS/ESP/gearbox error messages. I take great pride in trying to repair my car myself, but this problem I have not been able to complete yet, which brought me to this forum thread. Would it be possible to provide me ABS and ESP wiring diagrams? My car’s VIN number is: VF7**************[VIN obfuscated, can be read by forum staff] . Many thanks in advance!
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
@ trondrb
This is the ABS / ESP ASR+ System for your C4 PICASSO ESTATE - LEISURE 1.6 HDi 110 particle emission filter (DV6TED4) piloted manual gearbox 6:
Hi I have some kind of electrical problems with the connection between BSI and BSM.
Can you help me find what is connected on the pins of the BSI for my car?
My VIN is VF7**************[VIN obfuscated, can be read by forum staff]
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Not really it's too general - diagrams are by system as there are too many connections to list in one diagram so they are produced on a system by system basis. If you had an issue with one particular system, then a diagram can show the relevant connections between the BSI / BSM (if relevant) and the system in question.
I understand. Can you provide for my VIN the ABS/ESP and handbrake computer diagram connection with BSI?
