Electrican help please? Citroen C4GP ABS wiring mare (fixed)
- myglaren
- My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
C5, C5, Xantia, BX, GS, Visa.
R4, R11TXE, R14, R30TX - x 4920
Re: Electrican help please? Citroen C4GP ABS wiring mare (fixed)
It will sit in the outbox until Marc reads it, then will move to the Sent box.
- Paul-R
- Donor 2023
- Lexia Available: Yes
- My Cars: 2015 1.6 Blue HDi 120 Peugeot 308 Active SW
2013 2.0 HDi 163 C5 Exclusive Tourer
2003 2.0 HDi 110 C5 Exclusive Estate (Gone)
2001 2.0 HDi 90 Xsara Estate (Gone) - x 1378
If a PM is in the Outbox it simply means that it hasn't been read by the recipient yet. Marc probably has other things to do today and hasn't had time to look in here yet.
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5722
Hi Ian - on the Forum system, private messages sit in the outbox until the recipient has actually read them - it works slightly differently on the Forum that an email program. Anyway, here is the complete ESP system wiring Diagram for you. I have included the wiring descriptions for the main plugs below. I can't help with the colours of the wires, because in this case most of them are coded 'ND' non-defined - so could be anything. So focus on the pins.
If you need any more wiring codes for the others coming out of the ESP ECU, then just list them and I'll get back to you.
@ Steve / Paul - Yes - a new house kitten we have 'inherited and it got stuck behind a large unit - so guess what I have been doing since 03:30AM.....
Code | Description |
Hardware | N/A |
7825 | Rear RH ESP Sensor |
7820 | Rear LH ESP Sensor |
7815 | Front RH ESP Sensor |
7810 | Front LH ESP Sensor |
1611 | Clutch Release Pedal Angle Position Sensor |
7800 | Esp Ecu |
4410 | Brake Fluid Level Switch |
7804 | ESP Accelerometer Gyroscope |
7095 | Electric Handbrake Assembly / |
2120 | Brake Twin Function Switch / |
Wires | N/A |
7032U | Right-Hand Rear Wheel Speed Signal Reference |
7031U | Right-Hand Rear Wheel Speed Signal |
7022U | Left-Hand Rear Wheel Speed Signal Reference |
7021U | Left-Hand Rear Wheel Speed Signal |
7012U | Right-Hand Front Wheel Speed Signal Reference |
7011U | Right-Hand Front Wheel Speed Signal |
7002U | Left-Hand Front Wheel Speed Signal Reference |
7001U | Left-Hand Front Wheel Speed Signal |
- My Cars: C4 Picasso 07 1.6 HDI
Hi Marc / All - I needed to crack on and see what I could find continuity bit by bit...
So! Update: I managed to trace the continuity fault to the actual connector to the abs ecu - once I'd finally worked out it was possible to take the grey plastic mount off the bulk wire connector (/break in) and see the individual wire termination I found there was a break in the cable (completely corroded and green!) about 5cm from its final termination (so hidden in the connector head)! Patched a new wire to bridge the corroded gap and it's sorted it
If anyone was interested the yellow of the pair terminated one row up and slightly to the left from the arrowed pin on my previous image. which \following Marcs diagram, and spotting there was a tiny tiny number printed on the physical head the wiring diagram indeed matches up to the pin positon
Thanks for your help Marc - much appreciated!
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
No worries, another result, excellent work - it just goes to show how hidden some of these breakages can be.
- My Cars: 2009 Citroen C4GP
Im trying to find a pin out diagram of the ABS ECU socket. Which is pin 1, pin 2 etc... Can anyone help please?
I'm trying to locate a pin out diagram for a 2009 C4GP ECU plug. Which is pin 1, pin 2, etc....
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
In both cases I'll need a VIN to help you as diagrams are dependent upon options and specs.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
You'll need to put the VIN HERE. The system software masks the VIN from public view so it's fine to put it here - only staff can see it, but I cannot see it in a Private Message.pauljordanie wrote: ↑14 Nov 2018, 14:01 I'm trying to locate a pin out diagram for a 2009 C4GP ECU plug. Which is pin 1, pin 2, etc....
Ok VIN is VF7**************[VIN obfuscated, can be read by forum staff]. I'm also looking for the ABS plug pin numbering as well. Thanks.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Ok, here's the ESP / ABS ECU Diagram.
If you need some codes / wires identified let me know.
Thats great !! Thanks. Do you have the pin numbers for the plug that goes on the ABS ECU. Which is pin 1, pin 2 etc on the socket? I have the socket off the back of the unit. I look at the plug that I pulled off but I dont know which is which pin.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
The 32 Pin black socket shown at the top of the ESP ECU 7800:
Code | Pin | Description |
1941 | 10 | Alternator Starter ECU Sensor Earth |
1912 | 12 | Clutch Pedal Status Info |
1915 | 9 | +5 Volts Alternator-Starter Management ECU Sensor |
9010Z | 27 | High Intersystem 2 Can Bus |
9011Z | 15 | Low Intersystem 2 Can Bus |
442U | 8 | Brake Fluid Level Info |
BF03U | 1 | To Maxi Fuse 2 (Engine Fuse Box) |
BF04U | 25 | To Maxi Fuse 1 (Engine Fuse Box) |
ME10A | 38 | Electronic Earth |
7842U | 35 | Remote Control Wake-Up Information |
7112A | 32 | Angle Sensor + 12 V Power Supply |
9000U | 26 | High Intersystem / Can Bus |
9001U | 14 | Low Intersystem / Can Bus |
210U | 30 | Stoplamps Control |
MC10R | 13 | Earth |
Ok, but which pin is pin 1 on the plug? In the picture do I have my probe in pin 3 for example?
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
The numbers should be on the plug - but I can't see much from that picture - it's too dark and not very clear.
