Dual Climate control one side hot the other cold
Gazzaman22
(Donor 2022)
My Cars: Citroen C5 (2004-2008) 1.6hdi 5 door Hatch
Re: Dual Climate control one side hot the other cold
Post by Gazzaman22 »
GiveMeABreak wrote:I think the Mark 1 has separate temp controls. but not sure about the separate air distribution controls like the Mark II on, so would have the mixer flap, but the diagrams are not very useful.
Mine is more like your 4th picture.....
Okay thats very informative your diagrams.. thank you.
Do i need to replace "mixing flap" "No 3" in the diagram do you think?
Air temperature remains cold at present, Also i presumme the air distribution "No 2" is fine as the cold air can be put to the window,or floor or both places....
Are they the same sort of motor....could i swap them just to make sure thats my problem....or am i away off here :? :? :?
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow
x 5742
Post by GiveMeABreak »
Yes, yours is the last picture - I've looked it up from your VIN, which is why I needed to confirm the exact system.
Regarding which one to replace: It should be a process of elimination. Regardless of temperature, if you can adjust the the passenger side air distribution by pressing the passengers air distribution button, and then confirm with each press that the blown air direction changes according to the setting shown on the display (bear in mind it can take a few seconds for the motors to adjust), then you can assume that the distribution motor is doing its job.
If the temperature does not change as you've indicated, then this would indicate it is the mixer flap motor on the left that is not working and is the one to be replaced. You must make sure you align the spindle correctly when replacing the unit - it has a flat part on the spindle, so needs to align before forcing it on. The part number is 6447 RJ for item 2 (it should be the same part number for part 3 as there are no separate parts listed). They share the same part with Peugeot 407 and the wider part number is 4PUH19E616AB.
Here's one I found:
http://www.ebay.co.uk/itm/PEUGEOT-407-H ... 2247572760
Gazzaman22
(Donor 2022)
Yes the air direction does change.
Thats Brillant
Thanks for finding out this info for me.
You are a gentleman.
I'll order than in and see how replacement goes.
C15 Romahome White
CX 20 Polar White
x 5742
You're welcome, good luck and do let us know how you get on with the replacement :wink:
Dommo
My Cars: Current
07 C5 VTX+ 2.2 HDi 173hp
97 S1 Activa
06 Boxster S
93 XM 2.1 Turbo SD
Previous cars
91 Toyota Soarer UZZ32 Active Suspension
97 S1 VSX 1.9 Turbo D
99 Xantia Activa
98 2.1TD Xantia
99 306
x 19
Post by Dommo »
You must confirm whether it is the mixer flap itself that is broken or the motor, you don't want to order a motor for nothing! Watch this video for a bit more info on it:
It seems a bit butchery but there's no easy way of doing this fix. And the 407/C5 system is very similar.
Edit - Also, you can buy replacement flaps off ebay, but they're expensive. And nothing stops them failing again in my opinion, so when I do this repair I will do the araldite method as in the video above, as that will be stronger than when new.
http://www.ebay.co.uk/itm/251501599338
Cheers
Reason: YouTube tags
Gazzaman22
(Donor 2022)
Dommo wrote:You must confirm whether it is the mixer flap itself that is broken or the motor, you don't want to order a motor for nothing! Watch this video for a bit more info on it:
https://www.youtube.com/watch?v=sbbCMLEYVRc
Maybe best if i switch them motors about and that should tell me....
Dommo
My Cars: Current
97 S1 Activa
06 Boxster S
93 XM 2.1 Turbo SD
Previous cars
99 Xantia Activa
98 2.1TD Xantia
99 306
x 19
Post by Dommo »
I'd imagine if you removed the motor but left it electrically connected, you could see if it moves when you alter the temperature?
C15 Romahome White
CX 20 Polar White
x 5742
A good point on the flap itself Dommo. Always worth a check.
Gazzaman22
(Donor 2022)
Looks like i have to go down this route to fix.... Both motors are working...........
was hoping it was a motor..... wish me luck.... it wont be today....
Cheers
Gazzaman22
(Donor 2022)
Eventually got round to doing the fix above.... All worked out great.
Many thanks for all the help... Now i have to sort out a knocking/banging from the rear axle ( i think) i'll look in another forum for ideas
Tahnks
mickeymoon
Post by mickeymoon »
The noise will be the rear arm bearings being worn out...
My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
C5, C5, Xantia, BX, GS, Visa.
R4, R11TXE, R14, R30TX
x 4922
Post by myglaren »
Gazzaman22 wrote:Eventually got round to doing the fix above.... All worked out great.
I had a rattling from the rear that was commonly diagnosed as the trailing arm bearings. I was sceptical as it wasn't the usual cracking noise over speed bumps.
Asked the mechanic to give it a good coat of looking at when it was in for the MOT, which both he and the MOT tester did and they could find no fault with the bearings.
Turned out to be one of the brake pads clattering around, no anti-rattle springs present.
New pads and springs sorted that out quickly and cheaply.
Gazzaman22
(Donor 2022)
It's generally a banging noise when I go accross bumps...dips at speed
triumphtoledo
My Cars:
Post by triumphtoledo »
As the owner of 2 mark 2 C5s, I can confirm that the dual zone heater box is the same as the 407 - the motors tend to be fairly reliable and the heater and distribution are the same. Usually the heater flaps fracture and I found it far easier to remove the steering column, dash, and strip the heater unit on a bench. It all unbolts easily. I did this for Car Mechanics magazine, so there's a full step by step in there - just pay a few quid for a back issue.
R
Gazzaman22
(Donor 2022)
mickeymoon wrote: 18 Apr 2017, 20:58 The noise will be the rear arm bearings being worn out...
Hi, Do you reckon i would be fit to do a fix like this myself? Could you provide a link to this job being carried on out on a car. I'd consider my self okay at repairs so i'd have no problem in taking on with the job....Just looking for a guide
Please and thanks!
Post Reply
