We will discuss on Monday Alasdair... Until then, keep that big hammer at bay please...Stickyfinger wrote:Only those things that do not cost money, even when fixed the car is only worth £250 ......IF that.
Scrap hammer is hanging high
Well I have another one then !
- x 1591
Re: Well I have another one then !
- Donor 2016
- x 735
Well I managed to move it onto some small ramps JUST !
I checked the oil and even after the second drain and refill and the short drive it is still black as a witches tit !
Sunny today so the sump will come off and I will clean the filter, it still does not feel/sound nice. I know where my bet is placed...we shall see.
- x 1591
That's a very ornate hammer
- Donor 2016
- x 735
Only the best French Style Hammer for a Citroen Jim....so the shaft will most likely break the first time I use it, something inside will leak and put the fire out
- NOT Alistair or Simon
- x 1245
And (because it has not moved for a while) the brakes will seize mid-smite, the hammer will stop dead, and the wielder will spin head over heels.
- Donor 2016
- x 77
I think somewhere inside that car is a good box just waiting to get out!
Sent from my Wileyfox Swift using Tapatalk
- x 1591
Stickyfinger wrote:Only the best French Style Hammer for a Citroen Jim....so the shaft will most likely break the first time I use it, something inside will leak and put the fire out
- Donor 2016
- x 735
LOL...off out to pull the sump off this auto box and wash the filter......time will tell.
- x 1591
Fingers crossed it gives a very positive result Alasdair...Stickyfinger wrote:LOL...off out to pull the sump off this auto box and wash the filter......time will tell.
I drempt about it the other night and the filter in the dream was really mucky - like it was wearing a black fur coat... Hope that dream comes true
- Donor 2016
- x 735
Ok,,,,small stopper
The block support bracket is preventing the removal of the sump....Can I just remove the bracket from the support and the end of the block
- x 1591
Yes, you can...
No problems at all...
- Donor 2016
- x 735
Brill Jim....thanks mate
- Donor 2016
- x 735
and this is what I have....
I have not removed the filter yet as it got cold and dark
- x 1245
- x 1591
Now that does not look prima-facie very healthy Alasdair...
Looks like something may be in the process of breaking up...
Are the deposits visible in the sump away from the swarf magnet metallic in nature or are they bits of friction material or non-ferrous metal?
How big is the 'hedgehog' on the swarf magnet? Normally swarf magnet 'hedgehogs' look clean and spiky. That one looks really mucky as if the swarf is contaminated with something...
The state of the filter will be interesting and hopefully more revealing...
