Old Remote Key Fob into New Car?
OnlineGiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5741
Re: Old Remote Key Fob into New Car?
I know Citroen will provide you with the code if you can prove ownership, so I'm sure Peugeot will should you wish John. But it will be interesting to see your results from the experiment!
- (Donor 2021)
- My Cars: 2010 C5 X7 2.0 hdi 160 exc auto
MG TF 135
Boxer II 2.2 camper conversion
BMW R1200RT
BMW K1300 R
Honda V F R 800 5thG / MT500 Armstrong - x 39
thanks marc.. I will get that code .. but the locking unlocking is ever so slightly more pressing.. but before all of that the restoration needs an mot! wish me luck soon!
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
jgra, I think that what you're wanting to try is in part exactly what I was thinking about.
"as I have the basics in place I may try an old fob .. I cant quite see what harm it would do"
From what the ebay guidance linked in one of my earlier posts says, it's perhaps possible to get an old fob to lock / unlock. Keep us posted!
- x 5
2006 C4 1.6 HDi 16V (92) non FAP
2001 Xsara II 1.4 LX
2001 Renault Laguna II 1.9dCi Sport Tourer
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
Interesting, but I couldn't quite make it through 176 posts - still a hell of a faff and not for your average guy - but thanks for posting Unc.
Yeah, I was reading that thread too, it took up a fair bit of time to sift through!
- x 5
So in a nutshell,
It is possible to use a 2nd hand remote key and get the remote part working, however, it's not easy and requires a great knowledge of electronics and equipment to read the chips in the key fob... and probably a few months of your life
I think it's safe to say that it's probably better all round just to buy a new unused remote and programme that.
Cheers.
Cheers.
- Paul-R
- Donor 2023
- Lexia Available: Yes
- My Cars: 2015 1.6 Blue HDi 120 Peugeot 308 Active SW
2013 2.0 HDi 163 C5 Exclusive Tourer
2003 2.0 HDi 110 C5 Exclusive Estate (Gone)
2001 2.0 HDi 90 Xsara Estate (Gone) - x 1380
It's not that difficult.
This is the last time I'll say this but if you get the blade cut correctly and have a new ID46 chip then, with a Lexia or Diagbox, you can pair the virgin chip to the car.
- x 5
Paul-R wrote:No, it can be reassigned quite easily as long as the key blade and ID46 chip are working and recognised. This is where most attempts fail as they are trying to use an unrecognised key.cancunia wrote:Many thanks for the links, I've read through them and the overall view seems to be that the remote lock / unlock function is tied to a particular car and can't be changed.
Are you understanding that we are talking about using a 2nd hand key to do this with?Paul-R wrote:It's not that difficult.
We know how to programme the new transponder chip and fit it to a 2nd hand key....
We know how to get a new blade cut and fit it to the 2nd hand key....
So we now have a key that opens the doors manually and will turn on and start the car.
But how do we get the plip (remote locking) part to work on this 2nd hand key?
You seem to think you can just reassign it quite easily, there's a load of posts on the forum I linked to that seem to think different.
Care to tell us how you would do it, or have you said enough on the subject
Cheers.
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 3008
It may depend on the version of the car, but on my 2004 Xsara Picasso (company car) I had the engine running, and then pressed and held one of the key buttons (the lock one, IIRC) until the lock triggered. For this to work the car must 'know' the key (the immobiliser circuit) to allow it to accept the central locking remote functions.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- Paul-R
- Donor 2023
Yes.uncle buck wrote:Are you understanding that we are talking about using a 2nd hand key to do this with?
Then that's the difficult bit done.uncle buck wrote:We know how to programme the new transponder chip and fit it to a 2nd hand key....
It's not hugely difficult and basically as Hell Razor says although you don't need the engine to be running and I think it's already been posted.uncle buck wrote: But how do we get the plip (remote locking) part to work on this 2nd hand key?
Turn the ignition on.
Press and hold the lock button for 5 to 10 seconds.
Then turn the ignition off.
Wait a few seconds and then try locking the car from outside.
Something I should have asked before (which you may already have said) is whether you have an already working plip remote? If you have and that works then it shows that all the bits on the car are working. There's always a possibility that the receiver on the car isn't working if you don't know for sure.
So, if this doesn't work then the technique is not at fault there's something wrong with the plip board or receiver on the car. The first item to suspect is the battery in the plip but after that it could be anything.
- x 5
I'm not doing it I'm just reading the thread I believe it's cancunia that wants to do it.
We must be talking about different remote systems or something because it's all over the internet that it can't be done using a 2nd hand key. (by 2nd hand key I mean a key that is from a different car)
Yes you can do it easily with a new unused before key.
Have a read of the posts on the forum I linked to and you'll understand where we're coming from when we say it can't be done easily.
Cheers.
Cheers.
- (Donor 2021)
MG TF 135
BMW R1200RT
BMW K1300 R
thanks all, I am reading with interest as I mentioned in my post earlier..
I will get on to this within a couple of weeks, if no one else does first
John
a good point from Paul, if this system isn't happy then it may fail anyway..Something I should have asked before (which you may already have said) is whether you have an already working plip remote? If you have and that works then it shows that all the bits on the car are working. There's always a possibility that the receiver on the car isn't working if you don't know for sure.
John
- Paul-R
- Donor 2023
Sorry UB - It is a confusing thread.uncle buck wrote:I'm not doing it I'm just reading the thread I believe it's cancunia that wants to do it.
So many people have tried to use a SH key without changing the ID46 chip that this chatter has obscured the truth underneath.uncle buck wrote:We must be talking about different remote systems or something because it's all over the internet that it can't be done using a 2nd hand key. (by 2nd hand key I mean a key that is from a different car).
The difficult thing is getting hold of virgin ID46 chips. In fact for a long time we didn't know for sure that they were single use chips. You'll see some five of more years ago when I started out on this that I was learning as I was going along. I also went down several blind alleys (thinking that the ID46 chip might be useable for three reflashes for instance) so it's no wonder that it's a minefield to follow.uncle buck wrote:Have a read of the posts on the forum I linked to and you'll understand where we're coming from when we say it can't be done easily.
