Citroen C5 X7 Headlight Levelling
- My Cars: CX20 1983
Past glories:
Ami 8 Estate
2009 C5 Exclusive Tourer
C5 2008 Exclusive Saloon
C4 VTS coupé / C3 XTR
3 x XMs, 2 CXs
Visa 1.7 RD
Re: Citroen C5 X7 Headlight Levelling
I’m rather late joining this conversation, but my question relates closely to the discussion.
My recently acquired C5 tourer was riding way too high at the front, and since adjusting it (and transforming the ride and handling) the Xenon lights are pointing too low on the road and not illuminating far enough ahead. I can only presume that they had been adjusted to the previously incorrect running height - at an MOT test perhaps?
While the self levelling function is working properly, the ‘normal height’ setting is clearly incorrect.
Can anyone advise on the best way to adjust?
Scott
Scott
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5741
Hi Scott - yes, take it to ATS or somewhere like that as they have the proper beam testing equipment used for the MOTs. Just ask them to adjust the beams for you given that you have now had your suspension height settings corrected.
They did mine for me once for no charge when I had my MOT done - not long after I mistakenly turned the wrong screw on the headlamp unit whilst doing another job and thought I'd reversed the number of turns - but I obviously had mucked up the beam alignment.
It should only take them a few minutes generally.
Past glories:
Ami 8 Estate
3 x XMs, 2 CXs
Visa 1.7 RD
Thank you! I will do just that
Hi, another late addition to this thread: I've got a 2009 C5 X7 with directional bi-xenons. I live in Spain at the moment, and have matriculated the vehicle onto Spanish plates. During that process, surprisingly, the UK headlights passed the test even with a slight kick to the left, because the beams are still flat after the kick. 2 years later however they've changed the regulations so the car now fails annual inspection. My question is can I retrofit LHD halogens to this car, as to replace the bi-xenons is around 1200 euros!! or would I be upsetting the electronics?
- Paul-R
- Donor 2023
- Lexia Available: Yes
- My Cars: 2015 1.6 Blue HDi 120 Peugeot 308 Active SW
2013 2.0 HDi 163 C5 Exclusive Tourer
2003 2.0 HDi 110 C5 Exclusive Estate (Gone)
2001 2.0 HDi 90 Xsara Estate (Gone) - x 1379
I would think the easiest thing to do would be to change to RH Dip bi-xenons. There's all sorts of complication converting from fro bi-xenon to halogen, and vice-versa, which effectively make it a non-goer.
Time to start phoning round the car breakers.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Yes, agreed it's not just a matter of replacing the headlamp - the electrical harness is different, and the BSI may have a wobbly even when re-configured as the wiring / fuses will be different.
There was a similar post here:
viewtopic.php?t=57136
... but he never updated us on the outcome.
I suppose it's one of the costs one has to factor in if moving abroad permanently - change the lamps to LHD units or change the car.
Yes that post was mine! Apologies for not updating, I was taken ill shortly after that and forgot completely. So this post is the update. You're right, it seems the only option now is to go for new bi-xenons; the mot equivalent testers here even plug into the OBD connector to pick up any faults that have been logged, so anything non-standard may not show up. Many thanks for your amazingly quick responses. Chris
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Oops, I should picked up on that Chris!
What's your VIN - as there are several types of lamp fitted to the X7 (both Halogen and Xenons)
- Paul-R
- Donor 2023
No suppliers of S/H parts in Spain? There's also all of Europe as a possible source.chris_reade wrote: ↑22 Aug 2019, 10:49... it seems the only option now is to go for new bi-xenons;...
- moizeau
- My Cars: 91 BX TZD Estate. Dead but loved
407 HDI 136 auto
C4 2l petrol coupé
2010 Dispatch III HDI 90
AND a 1980 Z1000ST
AND a 1983 GPz1100 inj
AND a 1995 Zephyr 1100
AND a 1980 Z650 (my moped) - x 315
Tat yard, it's where I get my lights from when I bring a car to France.
Pete
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Yes, but these babies are over a grand each Pete....
Early Xenon lamp: £1154.02
Later Xenon lamp: £877.51
Now the good news - none of these include the ballast unit (£303) or the bulbs (circa £70+ each), but you will be able to use the existing ones with the new headlamps.
They are sought after and quite expensive - about £600-700 on the aftermarket and ebay ave practically zero of these. Once we have the VIN we can confirm model type and see if they can be had cheaper from Valeo which are about the guide price quoted above.
- moizeau
407 HDI 136 auto
C4 2l petrol coupé
AND a 1980 Z1000ST
I'll ask at my local tat yard. I've got to go there because the BX will become their property at the end of the month . 09 c5 X7?
Pete
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Don't know - we're still waiting on the OP for a VIN
- Paul-R
- Donor 2023
Yes, 2009. The VIN will give more information though.
Sorry for the bump..But I've got a question, I bought a 2nd hand '12 C5 with Halogen headlights, which is fine and I didn't see the need for bi-xenon ones, but there's an option on the screen between the gauge cluster for turning on or off the 'Directional headlights', is it an option on the screen in ALL cars or is it possible that my car used to have xenon's ar some point?
