I make no apologies for this being so far off topic that it's best viewed on another computer down at the bottom of the garden, but in an effort to educate in a way that a few of the regulars on here might find mildly interesting
Thats just the sort of thing "Picture(s) of the Day" thrives onbobins wrote: The 'converters' were on rolling stock and normally stored discreetly in out of the way places - short spur tunnels in the middle of nowhere etc. Somewhere I should have some photos of one of the tunnels - but it's not that interesting really
A clockwork motor on the Adam C - that'll be quite a wind-up thenNewcastleFalcon wrote:
And according to this article of 1st April 2016..a clockwork motor has been incorporated into the Vauxhall Adam C.
http://www.autoevolution.com/news/vauxh ... 06111.html
Regards Neilfrom
https://www.wired.com/2000/05/flywheel/
...The underlying concept is simple, though the finished flywheel assemblies become increasingly complex. First you feed electricity to a motor, which accelerates the wheel to cruising speed. Riding on magnetic bearings inside a vacuum container that eliminates air resistance, the wheel can spin almost indefinitely after you cut the power. When you want to tap its energy, you draw electricity back out of the motor, which now functions as a generator. This imposes a load on the wheel, gradually slowing it as mechanical energy is converted back to electricity.
In this way, the flywheel can substitute for a battery, while offering features that no battery can match. Even the most exotic battery can be damaged if you charge or discharge it too quickly. A flywheel isn't affected by this treatment, and can operate at extreme temperatures, can contain 10 times a battery's power density, and – according to its advocates – should last for decades.
Oh yes definitely!bobins wrote: If you can get on a tour to that place, it's definitely worth itOh yes !!
In fact I remember reading an article a few years ago saying that safety concerns were the primary reason why flywheels as a temporary storage device are not widely used in electric vehicles such as busses - because in the event of an accident if the flywheel was to break off its supports it would have so much rotational inertia and mass that it would rip through the side of the vehicle and flatten any other vehicles or people that happened to be in its path of destruction once it got free! Imagine seeing a 5 ton flywheel rolling down the motorway out of control...CitroJim wrote:Now that's some serious power and some seriously large flywheels! Imagine if one of those broke free...
Indeed, you only need to hold a spinning gyroscope in your hand to appreciate how it would make handing very 'interesting'... If you have no gyroscope available the same effect can be observed by handling a still-spinning computer hard disk!Mandrake wrote: Also lets not forget the difficulty of taking corners in a vehicle containing a spinning flywheel. Doesn't seem very optimal on the handling front.
CitroJim wrote:
Flywheels are used in some datacentre UPS systems nowadays to save the need of large banks of batteries. The flywheel will maintain the supply for as long as it takes for the diesel standby generators to fire up and take the load...
I know of one that works perfectly until it's actually needed in anger! It's tries to be too clever by half...
That's a neat little vehicleGibbo2286 wrote:I had a few rides on this, maybe ten years ago on my first visit to Santa Barbara.
http://www.santabarbaracarfree.org/how- ... us-around/
