207 Randomly Cuts Out...
'13 3008 1.6 HDi GripControl - x 1000
Re: 207 Randomly Cuts Out...
Jim,
Pop the top off the BSM cover and have a look at the number that is written on it (Looks like an old PSA part number beginning 96, but usually isn't!) - I might have one you can borrow for a trial....
Richard
Richard
OnlineCitroJim
- x 6201
- Contact:
Ahh, now that'll be valuable Richard, thanks Will have a opportunity later today... Easier now the battery is out...
I've got 2 actually.... (like you do!). One is the right one for my 307, which was procured to try on the C4 Picasso, but is not right for that - engine started with it in, but the wipers wouldn't work! I eventually bought a new one for the C4, and still have the old one which I think is OK in fact (as the fault was actually the EGR valve). I will fit the replacement to the 307 some time, as mine reports a fault where it can't see the DPF addititve ECU, and it smells a bit burnt!
- xantia_v6
- Lexia Available: Yes
- My Cars: -
1997 Citroen Xantia V6 (France)
1999 Citroen XM V6 ES9 (France)
2011 Peugeot 308 CC THP 155 (NZ)
1975 Jaguar XJ-S pre-HE (NZ) - x 834
Jim, have you got the PSA notes (from servicebox) about BSI operation modes and what is controlled by each output?
- Zelandeth
- My Cars: 2006 Peugeot Partner Escapade 1.6HDi.
1988 Renault 25 Monaco 2.0i.
1985 Sinclair C5.
1984 Trabant 601S.
1975 Rover 3500.
1973 AC Model-70. - x 1406
- Contact:
Drop me a line if you want a hand Jim, just around the corner and this sounds like quite the interesting challenge.
If you've still got it could drop the Activa battery on my smart charger and see if it can revive it - it's worked miracles on some wrecks before! Can never hurt to have spares...
Current fleet:
06 Peugeot Partner Escapade 1.6HDi, 88 Renault 25 Monaco, 85 Sinclair C5, 84 Trabant 601S, 75 Rover 3500, 73 AC Model 70.
OnlineCitroJim
- x 6201
- Contact:
No, I have nothing bar how to reinitialise the BSI Mike...xantia_v6 wrote:Jim, have you got the PSA notes (from servicebox) about BSI operation modes and what is controlled by each output?
Zel, thanks and appreciated Due to other priorities it won't be any time soon now. Other things are stepping to the fore....
OnlineCitroJim
- x 6201
- Contact:
The 207 is now back on the road after an MOT and is my daily driver now whilst Gabriel comes off the road for a heavy overhaul...
Just before the MOT, I stripped out the engine bay fusebox and Engine ECU and cleaned up every connection and every fuse...
I also cleaned every earth connection and found a slightly suspect one where the battery negative bonds to the bodyshell and then goes off to the gearbox..
The bonding pillar on the bodyshell was painted and the only contact was via a rusty bolt. I removed the paint to make a good connection and cleaned up the bolt...
She's not cut out yet but it's still early days...
I will report on how she goes over the coming weeks now she is back in regular and supervised use...
- My Cars: '95 Xantia 1.9D automatic - 118k one of two? remaining
'97 306 1.6 XS, 24k, The ex-Haynes "Max Power" display car. Bought after being written off & stripped, now being rebuilt without the wide body
'96 ZX 1.9TD SX, 81k new resurrection project saved from the scrapper - x 216
And this posted at 13.05 so it's not likely an April Fool's prank haha.
Good luck with it, hope it stays as "the pug of love" and doesn't decide to revert to it's "deathtrap" antics...
What's happening with Gabriel? and will it be documented on these forums? Heavy overhaul sounds like good reading!
'97 306 XS 1.6i, Blaze Yellow, 24k
'96 ZX SX 1.9TD rolling shell, White, 81k
OnlineCitroJim
- x 6201
- Contact:
No, definitely not an April Fools gag
Pug 207s have a charm of their own and a way of getting under your skin in much the same way a Xantia does...
Gabriel is coming off the road for a new heater matrix and a new clutch...
She deserves it, being such a good example...
Read all about my adventures on both two and four wheels in my blog here:
https://www.frenchcarforum.co.uk/forum/ ... 85#p527685
All I do these days is more or less fully documented there...
Good work Jim, I'm pleased to see it rewarded with an MOT.
Maybe you should get one of those "caution vehicle makes frequent stops" stickers just in case, not that anyone will take any notice.
- myglaren
- My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
C5, C5, Xantia, BX, GS, Visa.
R4, R11TXE, R14, R30TX - x 4921
My second daughter's birthday today and I realised that we have never stuck her with any April Fools tomfoolery.
Was she born after midday? Sounds like you've missed a trick or two.
OnlineCitroJim
- x 6201
- Contact:
elma wrote: Maybe you should get one of those "caution vehicle makes frequent stops" stickers just in case, not that anyone will take any notice.
Still plenty of time to rectify the situationmyglaren wrote:My second daughter's birthday today and I realised that we have never stuck her with any April Fools tomfoolery.
- myglaren
- My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
^ She lives on Teeside near Darlington and I'm not going back there today.
CitroJim wrote:No, definitely not an April Fools gag
Thanks for the link, will have a shufty round when I get a moment. Sounds like Peugeot have carried on a tradition started with the 205 then, as I do rate the 206 as one of those "subcutaneous" kind of cars also. I have to admit I/we have never really looked at the 207 with much fondness as the proportions just seem a bit strange compared to the 205, 206 and 208 too actually. If we ever do move towards "modern rubbish" for whatever reason I think the 208 was one of the cars we'd have to look into...
