Re_setting diesel additive level on C8
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5740
Re: Re_setting diesel additive level on C8
It is possible Alan - the trouble is that PSA used a whole lot of interchangeable injection systems for their engines - so determining which one means trawling under the hood if the diagnostic won't identify it, but then if there is a problem with the board, it's not going to help much down the road with the other things either
- My Cars: Citroen C8 2.0 Ltr hdi exclusive auto 2004
Citroen Berlingo 2.0 Ltr hdi 2004
Peugeot 806 1.9 TD 1993
Hi Marc not attached before so let me know if you can see this
[img]screenshot1[/img]
Alan
Alan
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
No image Alan - you'll need to upload it to an image hosting site like Photobucket (basic accounts are free) and that will generate the IMG code that you paste back into your post.
There's a guide here - I will be updating it soon, but it will give you the picture (so to speak)
https://www.frenchcarforum.co.uk/forum/ ... hp?t=35470
- myglaren
- My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
C5, C5, Xantia, BX, GS, Visa.
R4, R11TXE, R14, R30TX - x 4922
No.
Alan, you need to have that image hosted on a site such as PhotoBucket.
Shout up if you need any assistance with it.
Hi Marc, what a faff, I have been trying to upload image from an android tablet and it just kept failing so have fired up my pc and managed to do it from there. Lexia does global test, then onto injection which throws up this screen:
any help would be appreciated.
Regards Alan
Regards Alan
Reason: Fix Picture
Reason: Fix Picture
You nearly got it Alan, I just had to redo the link.
When you view your picture in photo bucket theres four links to the right of it. If you click the one labelled IMG it will copy and you just need to paste that into your post. Hope that makes sense.
Thanks for that James, is that on PC because it didn't do that on tablet.
Regards Alan
Regards Alan
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Alan, I think you have the 2.0 RHM Bosch variant, as this is the code in your VIN.
OK Marc will give that a try tomorrow and let you know what happens.
Thanks for help Alan
Yes it was by pc, theres a little grey chain button above the pictures as well. You should see it on a tablet, press it and the four links appear, IMG is at the bottom.
Hope your additive reset goes to plan.
Hi guys. Made a bit of progress today. Got as far as after sales then particle filter then reinitialize of total additive amount. It then says read then delete the additive total quantity parameter, I tried all sorts of things but could not see how to do this. However I did manage to open the BSI ecu and the diesel additive ecu and had a root around in those but couldn't find any levels or amounts that could be altered. I also came across a help screen for resetting additive level which I will screen print tomorrow.
Regards Alan
Regards Alan
