Urgent C5 radiator fan help needed
- white exec
Re: Urgent C5 radiator fan help needed
Yes, sorry - single fan on yours.
There is also a controlling relay attached.
Check out both fan and relay independently, and the supply to them.
You can substitute the fan with a high wattage lamp (eg 12v 100W, or 55W) for testing purposes.
- myglaren
- My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
C5, C5, Xantia, BX, GS, Visa.
R4, R11TXE, R14, R30TX - x 4888
Same here and I could be in trouble - had the bumper off to replace a blown bulb and the fan is sticking.Stickyfinger wrote:Single fan, single relay on mine.
Should be OK until next April though, temperature never varies
- Stickyfinger
- My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally - x 1280
- Contact:
I tried but could not gain access into the motor, I expect it is brushes causing the problems.
Activa, the Moose Rider
3x C5x7 Steering racks and counting
- myglaren
- My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
It just seems to be "tight" at one point in it's rotation. Very tight, wouldn't budge at first.
- Paul-R
- Donor 2023
- Lexia Available: Yes
- My Cars: 2015 1.6 Blue HDi 120 Peugeot 308 Active SW
2013 2.0 HDi 163 C5 Exclusive Tourer
2003 2.0 HDi 110 C5 Exclusive Estate (Gone)
2001 2.0 HDi 90 Xsara Estate (Gone) - x 1369
I would try some oil on the shaft to see if it can seep in and loosen it off. It will probably be best to take it out of the car first so that you can place it face down so that the oil can follow gravity.
Having said that, it'll probably not fix it. I never had any success with the fan out of either the C5 or the Xsara!
Saved a bunch on the fan ordering from that link. 500 vs 230.
Now got fault codes which are troubling from what I have read from searching this place.
C'est pas possible!
- Paul-R
- Donor 2023
Has that solved all your current problem(s) though?
- Stickyfinger
AX, little Daffodil
- Contact:
WHY ?
30mins bumper off, 30 mins to change the fan, 30 mins bumper back on + £230 for the fan unit.
Time taken looking for electrical fault. Then the Eolys was topped up and that stuff cost a load. £550 garage add the fan 250 (including postage) 800.
C'est pas possible!
- Stickyfinger
AX, little Daffodil
- Contact:
fair play, other stuff as well.
- Paul-R
- Donor 2023
Boris
Paul-R wrote:Has that solved all your current problem(s) though?
