Shuddering wiper blades
Re: Shuddering wiper blades
This "fog" won't wipe off when the window is cold though. It's as if you're looking through a very thick fog but it's purely on the outside of the glass. The wiper does reduce the thickness of the fog but does not wipe it away and it "re-fogs" in under 2 seconds since the last wipe. Utterly bizarre and I've seen nothing like it before.
Simon
1977 G Special 1129cc LHD
1978 CX 2400
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
This is what I used - it's definitely screen wash additive:Hell Razor5543 wrote:Erm, I didn't know that Rain-X came with an in-wash version. I always use a proper glass cleaner to get the outside of the windscreen spotlessly clean, and then I apply Rain-X in a polishing style, leave it for 10 - 20 minutes, and polish off the residue. If I have time I might do a second coating. That works for me.
http://www.halfords.com/motoring/engine ... tive-500ml
I did use "proper" glass cleaner on the window only a couple of months ago so it should be clean. The fogging has only started since the Rain X screen wash was added... I think you're right Jim, I need to go back to good old methylated spirits to clean the glass - it's what I used to use years ago and always worked well - for some reason I don't have much luck with "proper" glass cleaners!!CitroJim wrote:I've never been able to get on with Rain-X and found it seems to leave a greasy deposit. I find getting the screen spotlessly clean inside and out using solvent works well for me...
Is there an easy way to drain the contents of the screen wash bottle so I can go back to some "normal" cheapy screen wash ? Or do I just have to squirt it all out ?
Simon
1978 CX 2400
1978 CX 2400
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
The Rain X kit I had contained 2 compartments, the first a thorough cleaner for the glass to get all the oils, muck and grease off, then apply the Rain x in several coats after; never had a fogging issue on the outside with it.
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 3008
I remember that kit (I still have a bottle of glass cleaner left). The cleaner reminds me of Jif, thick white cream that (once you get the hang of it) got the windscreen so clean I had to go feeling for it.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
That's the one James!Hell Razor5543 wrote:I remember that kit (I still have a bottle of glass cleaner left). The cleaner reminds me of Jif, thick white cream that (once you get the hang of it) got the windscreen so clean I had to go feeling for it.
I think to be honest, that once your screen gets to the stage where it's very pitted, it won't matter what you put on as muck & grease will just end up in the fine holes and will probably wear away your wiper rubber! I tend replace mine when it gets to this stage as when sun is really bright, it accentuates and reflects all the micro holes and affects my eyes, so for the sake of £70 windscreen excess I think it's worth it.
That's all very well but I used the screen wash additive not the manual applicator kit and in the two years I have had the car I have never had any problems with the outside of the glass fogging up until I used this stuff. There's nothing wrong with the glass itself.
So I think the solution is to dump it out of the tank and put normal screen wash in, then clean the glass thoroughly with meths. Disappointing that an expensive screen wash has made such an arse of the job to the point where I literally can't see through the foggy layer on the outside of the glass until the window is warmed up a bit! Even if I try to manually wipe it with a cloth on the outside it doesn't clear the fog!
Simon
1978 CX 2400
1978 CX 2400
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Ahh, never used the additive - I just stick to the Halfrauds 5lt advanced and that never freezes in winter either. It will probably take a few goes to get all the residue off - a good glass cleaner will help - even that W2 stuff from Aldi does the house windows brilliantly.
