Replacing 5th gear - removing selector
- My Cars: Peugeot 205 TD
Citroen Jumper 2.5D
Peugeot 406 Estate 2.0 Hdi
Citroen Saxo Ph2 1.1
Audi A3 1.9D
Pembleton 3 Wheeler
1959 Kelsey GT
1957 Fordson Power Major Tractor
1964 Nuffield 4/60 Tractor
1967 Nuffield 10/60 Tractor
1963 Allis Chalmers ED40 Tractor
1984 JCB 3CX - x 39
Re: Replacing 5th gear - removing selector
Thanks Jim , you're a star
Jumper 2.5d
406 Phase 2 Estate, Hdi
Fiat 500 (2009)
1997 Audi A3 tdi
Peugeot 205 td
Fordson Major Tractor
Nuffield 460 tractor
JCB 3cx
Fiat 500 (2009)
1997 Audi A3 tdi
Peugeot 205 td
JCB 3cx
'13 3008 1.6 HDi GripControl - x 1003
Hadn't realised it was an ML box. I had a look at the procedure for stripping the box, but it doesn't specifically mention that part on the 5th gear - however, it does mention it on stripping the main shaft, and shows it in exactly in the position shown on the diagram. I think it's odds on you've got it in the wrong place....
Citroen Jumper 2.5D
Audi A3 1.9D
Pembleton 3 Wheeler
1959 Kelsey GT
1984 JCB 3CX - x 39
Hello Richard and thank you for the post.
We spoke to a friend last night who works on CamperVans. Because of the weight of them, they are famous for stripping the 5th gear.
He sais that the diagram was wrong and our assembly was correct.
Part "J" sits inside part "I" and part "K" sits between "11" and the "I and J" assembly.
When the selector fork pulls "I and J" onto "11", the ring ("K") slows "11" down so that the whole lot can mesh together smoothly.
Does this make sense how we have described it ?
Clucking into 5th means that "K" is worn and does not slow "11" down enough.
The oil in our gearbox was grey and only 1 year old and about 6000km, so its possible that "K" is also worn and has contaminated the oil, as its a phosphor-bronze part.
All an education to us , to be honest.
Going to take it for a test drive, fingers crossed.
As usual, the forum has once again been a great help.
Thanks to all.
Thanks to all.
Jumper 2.5d
Fiat 500 (2009)
1997 Audi A3 tdi
Peugeot 205 td
JCB 3cx
Fiat 500 (2009)
1997 Audi A3 tdi
Peugeot 205 td
JCB 3cx
- My Cars: Peugeot expert 1,6 hdi 2011
Hi I have Peugeot expert 1.6hdi 2011 in need to repair the 5th gear in the box does anyone know if I need to remove box from the van are can it be done with box still fitting thanks for any help
Can be replaced in situ
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5741
He means with the gearbox in place (without removing).
Spot on thanks wheeler and marc
- My Cars: Currently:
In the past: 3, CX td Safaris and about 7, XM td estates. Lovely cars. - x 1207
I did that on my last CX, lost synchro and repaired in situ, cant remember how, it was a long time ago, I only remember that every time I tried to put it back together ball bearings flew out everywhere, I eventually put a large piece of rag round it to catch them, I would think they have probably improved them by now.
Any one no the name of the proper socket to take 5th gear of
It's just a regular double hex socket that is used, cant remember the size off hand 26mm or 28mm maybe.
28 but can get one to go on
Never used anything special for this, just a normal bi hex socket. Done plenty of them, I always undo it with an impact wrench though. Maybe try the next size up?
Will do cheers
