Lexia -2- C2
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow
x 5706
Re: Lexia -2- C2
Post by GiveMeABreak »
wheeler wrote:
DHallworth wrote:My Lexia talks to all ECU's bar two on our X7. It says "no communication" when trying to talk to the directional headlights and says "unrecognised ECU" when talking to the telematics.
Talks fine to our 2009 C3 VTR though.
David.
Are you talking about a Lexia 2 or Lexia 3 though ? Lexia 3 shouldn't need any a additional adaptors. It's the older Lexia 2's that need extra bits to make them talk to newer models.
Well Easydiags sell the S1279 Module for the Lexia 3, so it must be required for certain vehicles and that's the Revision C full chip unit.
C15 Romahome White
CX 20 Polar White
x 5706
Re: Lexia -2- C2
It says "no communication" when trying to talk to the directional headlights and says "unrecognised ECU" when talking to the telematics. Talks fine to our 2009 C3 VTR though.
David.
If that was the case, then why would Easydiags be selling the S1279 Add On Module for the Lexia 3 Revision C? : S1279 Interface The S1279 seems to be needed for those cars that were joint developed by Fiat and PSA in order to read those vehicles like the Bipper, the Nemo, Jumper & Boxer AFAIK
I only mentioned the issue with the Berlingo before because from 2008 they developed 2 new models with FIAT - so that was why I thought the standard Lexia interface might have a problem reading some of the ECUs in Alasdair's post. :-D
Here's an extract from a Wiki that mentions the FIAT connection:
Two different models replaced the first generation of the Berlingo in 2008. The smaller, known as the Citroen Nemo,[6] was developed in cooperation with Fiat and Tofaş. Based on the Fiat Grande Punto platform, it is built in Turkey and is also marketed as the Peugeot Bipper and Fiat Fiorino. The Peugeot and Citroën are almost identical; the Fiorino also has a different, Fiat made, diesel engine. The Nemo is intended to be cheaper and smaller than the original Berlingo.
Donor 2023
My Cars: C5 Mk2 VTX+ estate.
x 3006
Re: Lexia -2- C2
Post by Hell Razor5543 »
I already mentioned that 'adaptor' and added a link in for it earlier in this thread.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
C15 Romahome White
CX 20 Polar White
x 5706
Re: Lexia -2- C2
Hell Razor5543 wrote:I already mentioned that 'adaptor' and added a link in for it earlier in this thread.
I know James, and I did refer to your originall post earlier in the thread, but I think it needed repeating / clarifying along the way :-D
My Cars:
x 728
Re: Lexia -2- C2
Post by wheeler »
David.
Sorry I wasn't very clear, Yes the Lexia 3 does still need the Fiat adaptor for certain models. I was meaning that Lexia 3 shouldn't need any extra bits for the C3 or the X7 that we were talking about in that's specific post.
Lexia 2 however requires a full CAN adaptor to fully communicate with full CAN vehicles. If you use it without the adaptor it will talk to certain ECU's, cant remember which exactly as its been a long time since I touched a Lexia 2.
Post Reply
