Hi Simon, sorry I have ment the "P1**" codes are vehicle bound. The Peugeot and Citroen both report this fault as: Permanent fault P1728. This then means : Can Data Bus, Torque signal - malfunction. The book says that possible faults could be: Wiring, APP sensor, ECM.
Some other cars like Ford reports this code fault to be too much slip in gbox.
The U1** codes are also vehicle bound.
Here are the different screen shots from Videos:
https://drive.google.com/open?id=0B6g9L ... G90S3ZiVGM
Can you or someone send me a photo of their Citroen C5 V6 2004 ZF gearbox TCM (transmission control unit) as well as a Peugot 406 with ZF 4HP20 gearbox's TCM label?
Hope that you find it nice reading time.
Kind regards,
Jan Calitz.
C5 V6 ZF 4HP20 Code P0782 2-3 Shift Malfunction
- My Cars: Citroen 2004 model C5 V6
