C5 X7 tyre pressure monitoring
Donor 2023
Lexia Available: Yes
My Cars: 2015 1.6 Blue HDi 120 Peugeot 308 Active SW
2013 2.0 HDi 163 C5 Exclusive Tourer
2003 2.0 HDi 110 C5 Exclusive Estate (Gone)
2001 2.0 HDi 90 Xsara Estate (Gone)
x 1369
Re: C5 X7 tyre pressure monitoring
Post by Paul-R »
What message are you getting? On my car it was something along the lines of "LH front tyre not being monitored" and this was fixed by replacing the valve sender.
Have you tried pressing the "Check" button on the lower RH side of the dash (next to the "Off" and ">P<" buttons)? This should give a readout of the tyre pressure status on the instrument panel screen.
"Trying is the first step towards failure" ~ Homer J Simpson​
C5_Jack
My Cars: Citroen C5 Tourer 2013 2.2 HDI
Caterham 21 ( for fun)
Post by C5_Jack »
I had a few issue with the TPMS recently.
What needs to be done if you get new sensor:
1) write down the sensor ID number for each wheel and location on the car
2) Fit wheel to the car
3) with diagbox set the ID number on correction location
4) job done
My local mechanic did that and it worked, he has a multi brand diagnostic computer tool thing
if you are locale to me (oxford) I may able to help set them if you have the ID numbers
Jack
Post Reply
