It goes wonky round corners
Re: It goes wonky round corners
If the rear suspension is similar to the Xantia (which I think it is but I'm not 100% sure) there are four round rubber bushes much like engine mountings that mount the rear suspension chassis to the body. They are deliberately designed to deform more easily in certain directions, this lets the rear suspension chassis twist under cornering and provides passive rear wheel steering.
If this is not working properly it can make the car twitchy under moderate to hard cornering. They don't often fail but when they do they can really upset the handling of the car when you push it around corners. When working properly they make the rear wheels turn slightly in the same direction as the front wheels under cornering load, thus providing some negative feedback to sudden steering input, making the car more stable.
https://en.wikipedia.org/wiki/Steering# ... l_steering
Simon
1977 G Special 1129cc LHD
1978 CX 2400
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
- swiveleyedgit
Ah yes, Citroen Service says 2 round bushes at the front of the crossmember and 2 square ones at the back, something else to look at. Hopefully I'll be able to check all these bits out tomorrow, the weather here is terrible today.
Bob
Current Citroen
2004 C5 2.0 Litre HDI VTR Auto
Current Citroen
- swiveleyedgit
Well I finally got round to having a look at the car today, the nearside bottom ball joint is knackered. It was newly fitted about six months ago so I'm assuming the quality wasn't up to much!
I'll replace it Monday and see if the wonkiness has disappeared.
Bob
Current Citroen
Current Citroen
- My Cars: Currently:
In the past: 3, CX td Safaris and about 7, XM td estates. Lovely cars. - x 1207
Could be a faulty tyre.
- swiveleyedgit
The wonkiness has gone, twas the ball joint. I've replaced the offside one as well, it wasn't anywhere near as bad as the other one but I thought I may as well do it while all the tools were out.
I'm going to check the drop links and bushes today as there's something rattling over the bumps still, these were only changed a few months ago as well. I was wondering if there was anything on the steering column that wears as the noise seems to be coming more from beneath my feet?
Bob
Current Citroen
Current Citroen
Like an elf with a little hammer under the car right where your feet are? If so that's a droplinks for sure, they get manufactured worse every year. I've had cheap ones give up in as little as 35 miles.
- swiveleyedgit
Yes, that's a good description. I'll have a look this morning, is there any point in getting replacements from the main dealer if they need changing? There seems to be a variation in quality with these from third party suppliers.
Bob
Current Citroen
Current Citroen
- swiveleyedgit
Got a pair of Delphi drop links from my local factor, 10 quid each, no noise at all now!
Only got to get the tracking done again now as it moved when I replaced the ball joints
Bob
Current Citroen
Current Citroen
Changing the drop links won't change the wheel alignment.
Either you're not measuring it accurately or the lower arm bushes are soft causing the measurement to change when the car moves and the lower arm settles in a slightly different place...
Simon
1978 CX 2400
1978 CX 2400
- swiveleyedgit
No Simon, the tracking changed when I replaced the bottom ball joints. I had it tracked when the new tyres were fitted and to be fair they made a good job of it, but unbeknown to me at the time (this was about 6 or 7 weeks ago) the ball joints were worn and now I've replaced them the tracking is slightly out.
Bob
Current Citroen
Current Citroen
Do the tracking yourself!
You only need something like an adjustable clothes prop which will fit between the inner rims, and half an hour or less.
A length of threaded rod slid into a metal tube gives a pretty accurate adjustment, I have used this for many years.
Please explain...
I would put a picture on but I don't know how to do it What I use is about 3' of threaded rod about 1/2" in diameter with two adjustable nuts fitted, this is slid into a length of suitably sized tubing so that the length can be adjusted by the nuts, I use two nuts so the rod can be fitted the other way round for a car with a different track width.
Adjust the length so that it just touches the inside edge of the tyres at the front of the wheel level with the bottom of the wheel, move it to the rear of the wheel in the same position and it will be a looser fit or there will actually be a gap, that is if the wheels are towing in, if its tighter or the gap is smaller they are towing out.
The tow in - out measurement will be found in the workshop manual or possibly on line but most cars have the wheels almost parallel, is usually about 1/16" to 1/8th" but that is at the wheel rim so on the tyre it will be a little less but it isn't that critical on most cars, I find that a tight fit one end and a loose one the other works fine and set like this I have never had a problem with uneven tyre wear.
Thanks Peter, I'll show you the pictures thing another time when I'm not dozing off.
