C5 Mk III suspension issues
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
Re: C5 Mk III suspension issues
I'll see if I can pump some screenwash out using the pond pump tomorrow as I can't remember whether it was a written warning Message or a bulb type message! I don't know, the things we do here ....
- Stickyfinger
- My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally - x 1299
- Contact:
hit it with a Percy
Activa, the Moose Rider
3x C5x7 Steering racks and counting
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
- Locked user account
- My Cars: A used Citroen
- x 27
@ sticky - Do you have xenon or halogen headlamps?
- Stickyfinger
AX, little Daffodil
- Contact:
halogen headlamps
- x 27
That's why ... only the xenon's have the washing fluid sensor fitted and activated (due to the larger washing fluid container - for the headlamps washing as well)
- Stickyfinger
AX, little Daffodil
- Contact:
Well I never.....stupid, just stupid
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Well that's saved me from pumping out the fluid! 10/10 VAB
- x 27
Ask me ... I wanted to retrofit it ... ... it might be done, but for the level sensor to be active you need to enable the headlamp washing system ... when that's enabled, it tries to link the xenons ... which I don't have ... let alone directional and leveling ECUs ... meaning, I'd have a washing level sensors active, and about 10 permanent errors due to missing equipment ... ... my dad's C5 2005 has that feature without the xenons ... go figure the Citroen's logic in that...
- Stickyfinger
AX, little Daffodil
- Contact:
Both my Mk1 and Facelift had it with standard bulbs.....as did they a bonnet lift ram.....another go figure ?
- My Cars: Now:
C5 X7 HDi 240 Exclusive Tourer
ZOE 22kwh Intense
Before:
C4 1,6 Coupe Automatic
C5 X7 HDi136 Exclusive Sedan A
Xantia HDi110 Berline
Xantia 1,8SX Berline - x 28
I've got halogens and fluid sensor. I have headlamp washers as well.vborovic wrote:That's why ... only the xenon's have the washing fluid sensor fitted and activated (due to the larger washing fluid container - for the headlamps washing as well)
And I don't like that feature very much, just another annoying beeping sound.
- x 27
That was standard or did you switch to halogen headlamps from the xenons (people actually do that)? All the available data I have never showed an option halogen + washers (you couldn't even order such a combination) ... then again, it's all up to the market and the car variants
- My Cars: Now:
ZOE 22kwh Intense
Before:
No, I think all C5's in Finland have headlamp washers. Long winter, salty roads and so on...
- x 27
That means there should also be a combination in the BSI that allows for the headlamp washers option (+ washing fluid level sensor), without the xenons ... I'll have to go through the configuration options once again ...
- My Cars: Now:
ZOE 22kwh Intense
Before:
Btw, noticed with Lexia that headlight height ecu or something like that is not present. Same thing with two X7's with hydropneumatic suspension. So retrofitting xenon-headlights would mean also adding that ecu-thing. Height sensors are already there, but without brains for xenons.
