C5 facelift dipped beam lamp fitment problem?
- white exec
- myglaren
- My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
C5, C5, Xantia, BX, GS, Visa.
R4, R11TXE, R14, R30TX - x 4922
Re: C5 facelift dipped beam lamp fitment problem?
Unless you have Xenons, according to my handbook,
H7 for dipped beam, H4 for main & fog.
- myglaren
- My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
There are instructions and photo's for H7 fitting here
For C4 but should be the same.
- Paul-R
- Donor 2023
- Lexia Available: Yes
- My Cars: 2015 1.6 Blue HDi 120 Peugeot 308 Active SW
2013 2.0 HDi 163 C5 Exclusive Tourer
2003 2.0 HDi 110 C5 Exclusive Estate (Gone)
2001 2.0 HDi 90 Xsara Estate (Gone) - x 1379
More or less what I said!myglaren wrote:H7 for dipped beam, H4 for main & fog.
The flashing is probably a faulty comms unit, mine was doing this, since i got it replaced no more flashing lights.
CX GTI 2 Turbo (LHD) - Sorn
Bx Gti 16v
BX TZD Turbo - Sorn
C5 Mk1 LX 2.0HDi Estate
Mini Cooper D Clubman
Bx Gti 16v
BX TZD Turbo - Sorn
- white exec
That's wrong. In the photos, 1 and 3 are hinge-points for the retaining spring, which lowers so it doesn't get lost. Release is by unhooking at 2. Might need a small pair of pliers.myglaren wrote:There are instructions and photo's for H7 fitting here
- My Cars: 2005 C5restyle 1.6HDI 16v 110hp VTR Estate
2008 C5 X7 1.6HDI VTR+ Saloon - x 231
Sorry, thought I'd replied (it's an H7).
Tried having a feel around the lamp today. With rubber cap off, I could feel the connector and tried feeling for any play. To my surprise, against slight spring tension, I was able to push down on the end of the connector and observing through the glass, saw the bulb tilt upwards. While it "feels" like there's enough spring tension to resist bumps and shocks and restore it to level, might it explain why it appears the beam pattern sometimes looks a tad higher than it should? I don't know.
I'd be most interested to know if this common for this model (perhaps another member would be so kind as to try this experiment on theirs?) or something is not right with the fitting.
