Wave as you pass Lanark, Davie!
Surprisingly the book time for the clutch is only 6.5 hours - think you'd have to motoring to do that! Mind you book time for a C5 Mk2 2.0 HDi is only 5.5 hours, and I know from experience you'd REALLY have to be motoring to do that!
Davie's Activa Clutch
- x 347
Re: Davie's Activa Clutch
We all know that book time is fiction though right ?
- x 1510
Up there with the best of them.. proper Mills and Boon stuff...Mandrake wrote:We all know that book time is fiction though right ?
6.5 HoursRichardW wrote: Surprisingly the book time for the clutch is only 6.5 hours
Poor old Davie's has taken nearly 6.5 Months
You don't use a clock to measure my repair times, you use a calendar...
- Donor 2016
- x 735
or the planets, when Mercury lines with Mars and the moon is in the 7th sun....your done
- NOT Alistair or Simon
- x 1196
While you might need a calendar to time Jim in his work, you would have to wait until the planets align before his work would fail. Slow he may be, but reliable he DEFINITELY is.
- Donor 2020
- x 327
Re: RE: Re: Davie's Activa Clutch
And reliable is what I want. I would rather know that the jobs are done properly and no quick fix bodge jobs. A quick fix bodge job has its place at times, but not on a special keeper.Hell Razor5543 wrote:While you might need a calendar to time Jim in his work, you would have to wait until the planets align before his work would fail. Slow he may be, but reliable he DEFINITELY is.
Sent from my SM-G361F using Tapatalk
- x 1510
Ahh, so this is perhaps not the best time to tell you I re-used your old clutch, bodged up the handbrake cables with baler twine and relined the brake pads with plywood then..daviemck2006 wrote:Hell Razor5543 wrote: A quick fix bodge job has its place at times, but not on a special keeper.
Amazing how you can shine up old brake discs with a brillo pad!
I also re-used the old oil from the gearbox...
The new stuff you bought Davie, I sold for a massive profit on eBay...
- Donor 2020
- x 327
As long as you put in the new release bearing its all ok though!
- x 1510
daviemck2006 wrote:As long as you put in the new release bearing its all ok though!
Had to, just couldn't bodge that one up!
- Donor 2020
- x 327
That's ok then, everything works [emoji13] [emoji23]
- Not Mike
- x 33
It's still there!
- x 1510
It is indeed but moved off the drive
That's a great picture!
Burnley Ben eh?
I could use an ACTIVA badge and tailblazer just like that
You any good with Photoshop
- Donor 2016
- x 735
tailblazer, now there is a blast from the past
Got one of those boxed 'in the shed' as well [emoji1] It's like tutankhamun's tomb in there [emoji1] [emoji1] [emoji1]Stickyfinger wrote:tailblazer, now there is a blast from the past
Sent from my LG-D855 using Tapatalk
