Davie's Activa Clutch
BenC5HDi
Not Mike
x 45
Re: RE: Re: Davie's Activa Clutch
Unread post by BenC5HDi »
daviemck2006 wrote:That would be good Ben, but the travel plans are on hold until him gets the seal fitted and the car tried out.I will keep you in the know for when I travel. I'm not going to jump the gun
Sent from my SM-G361F using Tapatalk
Yes I know all that. We can read south of the border too....
Donor 2023
x 3159
daviemck2006 wrote:
Hell Razor5543 wrote:What I love about this forum is that members will go the extra parsec to help each other.
It's absolutely brilliant James. I've also had offers of driving the car up to me and I drop off at the airport if I'm not well enough to drive the distance. I just love this forum. It's by far the friendliest and most helpful one I have ever been on.
And that is in spite of me being a member!
daviemck2006
x 492
Unread post by daviemck2006 »
I'm hoping it's Tuesday, and either just before 1pm, or just after 10 pm, the earlier one vastly preferable
Skoda Karoq 1.6tdi 2018
Citroen dispatch 2014
In the family
Seat Leon 1.5tsi tourer 2019 daughter 1
C1 vtr+ 2010 daughter 2
superloopy
x 18
Unread post by superloopy »
CitroJim wrote:
xantiamanic wrote: How did you manage to prise the end off that blue cylinder and wouldn't that itself allow air into the system?
Mike, by way of clarification, the slave and pipe shown in the first two pictures mounted in the vice in my workshop is NOT the one from Davie's car, it is a spare I had in stock as a complete spare that was complete but dry of fluid almost... Hence why I used it as a proof of concept and as a practice-piece....
Didn't want to do anything to the one on the car until I was 100% sure of what I was doing ;)
Sorry Jim ... I can only see the blue cylinder so that's NOT where you are topping up then?
Bit confusing as to how you can top up and maintain it's air tightness, it is mounted horizontally isn't it or is the 'lid' at its high point somewhere amongst all those pipes?
Mike
Xantia Activa Dante Red MK1 (96) 121k - SORN, to be broken
Xantia Activa Silex Grey MK2 (98) 120k -SORN, ditto
Xantia V6 Silex Grey MK2 (98) 95k - non-runner
Xantia TD Storm Grey MK1 (95) 95k - non-runner
daviemck2006
x 492
Are you claiming to be unfriendly and unhelpful James. [emoji12] [emoji37] [emoji13] [emoji23]
In the family
Donor 2023
x 3159
:lol: Who, me?
daviemck2006
x 492
Would I insinuate such a thing[emoji15] [emoji23]
In the family
Donor 2023
x 3159
:twisted: No, but I would (about me).
x 1021
Unread post by xantia_v6 »
CitroJim wrote: Bleed it exactly like you would conventional brakes... Pedal down open bleed screw, close bleed screw, pedal up and repeat until it's all good. Keep an eye on master cylinder level ;)
I wish I had been there to see you do that on you own...
x 1671
Unread post by Stickyfinger »
x 7124
xantiamanic wrote: Sorry Jim ... I can only see the blue cylinder so that's NOT where you are topping up then?
Mike, I don't go near the blue cylinder. Look again to the left of the heater matrix elbow and if you look very carefully you’ll see the master cylinder reservoir! It really is well hidden and virtually inaccessible....
I can understand the confusion because it is so hard to see and the blue cylinder (which is a strictly one-time connector) is so visible.
xantia_v6 wrote:I wish I had been there to see you do that on you own...
It's amazing what you can do with a very heavy brick on the clutch pedal Mike!!!
x 7124
Stickyfinger wrote:Image
That's a good likeness of me ;)
superloopy
x 18
I see it now Jim .... just!
Does that lid prise off easily?
What exactly is that little blue cylinder (just wondering the signifiance of it's colour that's all).
Mike
superloopy
x 18
Reason I ask is that activa1 (the flaking, algae ridden MK1 Dante Red activa) had a new complete hydraulic system including that blue thing as a condition of sale by me when I bought it, the pedal was on the floor and the guy selling didn't want to fix. I understand why now. So we 'negotiated' and his local garage fitted the whole thing - £400 :o
Mike
x 7124
Oh yes, they're horribly expensive Mike! I believe they may now be NFP..
Yes, the lid prises off easily enough but it has a membrane underneath it like a strong balloon... This can obscure the real level in the reservoir...
The little blue cylinder is a one-time joint. The new kits come in two halves, already filled and bled. The two halves are fitted and then joined once both are in place... Without that joint it would be impossible to fit without removing the engine and gawd knows what else!
