AX fitting airco system
- jsp
- My Cars: AX 3x 10E 1.4 GTI 5drs 1.0i
CX 2x GTI turbo
ID 19 1960
Now:
1960 ID 19
1984 CX GTI Turbo 1
1987 CX GTI Turbo 2
1987 AX 10E Pino
1994 AX 1.4 5dr TGS GTI
1994 AX 1.0 3dr Escapade
1996 AX 1.1 3dr spot Burgundy
1996 AX 1.1 5dr Verte
2003 peugeot 206 xs leather with auto A/C - x 12
Re: AX fitting airco system
Electrical diagram please (berlingo 1.9D also ok)
My Citroens update:
http://www.frenchcarforum.co.uk/forum/v ... 14&t=50070
- xantia_v6
- Lexia Available: Yes
- My Cars: -
1997 Citroen Xantia V6 (France)
1999 Citroen XM V6 ES9 (France)
2011 Peugeot 308 CC THP 155 (NZ)
1975 Jaguar XJ-S pre-HE (NZ) - x 835
I think he needs the A/C system wiring diagram for a 1997 (LHD) Saxo, as he has transplanted the A/C system from one of those into his AX. The key item is the connections to the 7 wire controller box pictured above.
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5741
Ok, this is from a 1997 Saxo Diesel with A/C - specifically showing 8035: Passenger Compartment Temperature Electronic Thermostat (where separate). Note: Pins 3 & 4 show the same - this is not a typing error, and additionally, on the diagram you cn see they seem to link together. On tha larger Wiring Diagram, they do not show a destination as you can see.
Here's the Wiring for the Unit (according to the Saxo Diagram)
Here's a table showing the key components:
Here's the Electrical Diagram from the Saxo:
Pin | Code | Description |
1 | 8051 | Evaporation Sensor Command |
2 | 8052 | Evaporator Sensor Info |
3 | 80 | BPGA BFH5 Permanent+ |
4 | 80 | BPGA BFH5 Permanent+ |
5 | 807 | Air Intake Motor 2 Control |
6 | M8035 | Air Inlet Motor Potentiometer - Power Supply (Earth) |
7 | 805 | Electronic Thermostat Command |
8000 | Air Conditioning Switch |
8001 | Air Conditioning Compressor Relay Shunt |
8035 | Passenger Compartment Temperature Electronic Thermostat (Where Separate). |
8004 | Air Conditioning Cut-Off Control Unit / |
8006 | Evaporator Thermistor (If Separate) |
8007 | / Pressostat |
8008 | Air Conditioning Engine Coolant Temperature Thermistor |
8010 | Coolant Temperature Unit (/) |
8015 | Compressor Cut-Off Relay Controlled by Coolant Temperature Unit (/) |
8020 | Air Conditioning Compressor |
8067 | Air Inlet Flap Control |
8070 | Air Inlet Flap Reduction Motor |
BPGA | Electrical Supplies Protection & Management Unit |
- jsp
CX 2x GTI turbo
ID 19 1960
Now:
1960 ID 19
1984 CX GTI Turbo 1
1987 CX GTI Turbo 2
1987 AX 10E Pino
Many Many thanks now I can wire it up after so many hours.
My Citroens update:
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
No problems, I must of missed this post, or I would of responded earlier
- jsp
CX 2x GTI turbo
ID 19 1960
Now:
1960 ID 19
1984 CX GTI Turbo 1
1987 CX GTI Turbo 2
1987 AX 10E Pino
Thanks what does 8010 do exactly. I was making the wiring but, seems I don't have this computer? I am doing this A/C refit on a Carb car.
My Citroens update:
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
I believe that this is some form of a coolant sensor on the radiator circuit. I think it is to avoid the engine overheating, so the coolant water is monitored by the air conditioning system.
On some vehicles, if the coolant temperature gets to above 117°C, the compressor clutch is switched on and off at 20s intervals. If the coolant temperature exceeds 120°C, the electromagnetic switch is switched off until the temperature drops below 117°C. The clutch then cuts in once again at a rate of 100%. This is a generalisation - and each A/C system will be different - more modern systems don't have this specific module, the function is probably an integrated into the newer electrical systems.
- xantia_v6
- My Cars: -
As far as I can see, 8010 is the cooling fan controller, and when it detects overheating it shuts off the A/C compressor clutch via relay 8015. If you feel you need a similar function, you could drive a relay from the overheat warning light (assuming you have one).
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
I omitted the 8015: Compressor Cut-Off Relay Controlled by Coolant Temperature Unit (8010) and 8001 the Relay Shunt - I'll edit the previous table to include it.
- jsp
CX 2x GTI turbo
ID 19 1960
Now:
1960 ID 19
1984 CX GTI Turbo 1
1987 CX GTI Turbo 2
1987 AX 10E Pino
Ok many thanks.
I don't know if the older carb cars had such a computer to turn the fan on. Normally its just relay and fan switch and fan.
Could I use a 2 pin low pressure switch for this?
If yes how to wire?
8004 ''
8067 Seems I dont have a recirculate function / bypass this function?
If yes how to wire?
8004 ''
My Citroens update:
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
I really couldn't say, all the systems are different and moreso on later cars - I really can't advise you on the wiring as this is a retro fit and from a different model - mine is a computer controlled climate system, so completely different.
Have you thought about contacting a local automotive Air Conditioning engineer? That might be your best option.
- xantia_v6
- My Cars: -
If your car currently has a single-speed fan controlled by a simple thermal switch, then the "period" means of actuating the fan from the A/C is to add a relay across the thermal switch that brings on the fan when the compressor is requested by the compressor controller. The coil for this relay should be connected directly to the compressor controller (before the compressor cut-out relay) so that the fan is kept on in the event of over-pressure in the A/C system.
- jsp
CX 2x GTI turbo
ID 19 1960
Now:
1960 ID 19
1984 CX GTI Turbo 1
1987 CX GTI Turbo 2
1987 AX 10E Pino
GiveMeABreak wrote: ↑18 Sep 2018, 15:32 I really couldn't say, all the systems are different and moreso on later cars - I really can't advise you on the wiring as this is a retro fit and from a different model - mine is a computer controlled climate system, so completely different.
They don't want to tell and just keep hammering you need a custom a/c just upselling.
xantia_v6 wrote: ↑18 Sep 2018, 16:26 If your car currently has a single-speed fan controlled by a simple thermal switch, then the "period" means of actuating the fan from the A/C is to add a relay across the thermal switch that brings on the fan when the compressor is requested by the compressor controller. The coil for this relay should be connected directly to the compressor controller (before the compressor cut-out relay) so that the fan is kept on in the event of over-pressure in the A/C system.
Yes it only has single speed. I was think adding a second fan building the cooling system into a ''push-pull'' configuration and only use the second fan as A/C fan only.
With the 8010 you mean this relay right?
My Citroens update:
- xantia_v6
- My Cars: -
My ideas for wiring are:
8007 is the A/C pressure switch, I have shown only the compressor cutoff contacts connected, the other set of contacts, should really bring on the cooling fan.
8015 is still the compressor cutoff relay (in case of engine overheating) The sense of the wiring to the relay coil will depend on the overheat sensor on the AX.
[edit] To clarify, there should be 3 interconnections between the A/C system and the AX cooling system:
1. The AX overheat sensor should cut off the A/C compressor
2. The A/C compressor enable signal should bring on the cooling fan
3. The A/C pressure switch (second contacts) should bring on the cooling fan (not shown in the diagram in this post).
I have assumed that you are using the Saxo dashboard switches and A/C blower controller (things can be simplified further if you are not).8007 is the A/C pressure switch, I have shown only the compressor cutoff contacts connected, the other set of contacts, should really bring on the cooling fan.
- white exec
May or may not be of any use, but here is the basics of a twin-fan cooling installation, with relay added for triggering low-speed when AC is switched on.
Uses a standard radiator thermo-switch.
Dash LEDs and manual switching is an optional extra.
Circuit equates to the standard 3-relay arrangement on many Citroens.
