AX fitting airco system
- My Cars: '95 Xantia 1.9D automatic - 118k one of two? remaining
'97 306 1.6 XS, 24k, The ex-Haynes "Max Power" display car. Bought after being written off & stripped, now being rebuilt without the wide body
'96 ZX 1.9TD SX, 81k new resurrection project saved from the scrapper - x 216
Re: AX fitting airco system
Oh yeh, nothing is impossible if you want it enough & it's a good point about the AX being possibly similar to the 106 (and saxo, which appears to be the favoured donor in this case). Also the job may be helped along if the car being converted is LHD, I don't know but I think it may be as the OP is in the Netherlands... What side do they drive on~? lol
I would gather from the OP's "fleet" that they're pretty enamoured with the little Cit and more than likely au fait with the general make-up of the car so I can see it being doable if they want an "AX AC", I do think the primary stumbling block would be the heater box/space, and how efficient the system could be with whatever size evaporator is able to be fitted but it's certainly possible. Just whether it turns out being a worthwhile addition usability-wise is what I'm not 100% on, very interested nonetheless to see where this goes & I wish the OP all the best in their project
'97 306 XS 1.6i, Blaze Yellow, 24k
'96 ZX SX 1.9TD rolling shell, White, 81k
- jsp
- My Cars: AX 3x 10E 1.4 GTI 5drs 1.0i
CX 2x GTI turbo
ID 19 1960
Now:
1960 ID 19
1984 CX GTI Turbo 1
1987 CX GTI Turbo 2
1987 AX 10E Pino
1994 AX 1.4 5dr TGS GTI
1994 AX 1.0 3dr Escapade
1996 AX 1.1 3dr spot Burgundy
1996 AX 1.1 5dr Verte
2003 peugeot 206 xs leather with auto A/C - x 12
I have LHD car should be easy to fit.
My Citroens update:
http://www.frenchcarforum.co.uk/forum/v ... 14&t=50070
- spider
- My Cars: Soon, I hope...
- x 77
- Contact:
LHD would be easier as you can then (as already put) 'target' a LHD Saxo or 106 with AC as a donor.
Seems I have to register again to look at Citroen SBox as the Peugeot login credentials are not accepted, something I would of thought they would be.
I was merely going to see if *any* (sold anywhere) AX had AC fitted...
Andy.
- jsp
CX 2x GTI turbo
ID 19 1960
Now:
1960 ID 19
1984 CX GTI Turbo 1
1987 CX GTI Turbo 2
1987 AX 10E Pino
Thanks all Mine is LHD so will fit.
My Citroens update:
- My Cars: On road: Grand Espace 3.5 V6 (waft), Megane Coupé F4R (vroom), Bertie the Berlingo (Mrs Optix's).
In field: 1989/G BX 16v, 1988/F BX 16v
Historic: C5s, Synergies, AX 1.5d, Renault 4, 406 (of Satan) and a 106 (of Satan). - x 1
The main thing you will need is expletives. Make sure you have all the expletives you will need to hand, and get experienced in using them.
- jsp
CX 2x GTI turbo
ID 19 1960
Now:
1960 ID 19
1984 CX GTI Turbo 1
1987 CX GTI Turbo 2
1987 AX 10E Pino
All the parts you mean?
My Citroens update:
- x 24
Nope, he means all the swear words you can get your hands on
- jsp
CX 2x GTI turbo
ID 19 1960
Now:
1960 ID 19
1984 CX GTI Turbo 1
1987 CX GTI Turbo 2
1987 AX 10E Pino
XD Will get from a saxo the parts and looming XD
My Citroens update:
- jsp
CX 2x GTI turbo
ID 19 1960
Now:
1960 ID 19
1984 CX GTI Turbo 1
1987 CX GTI Turbo 2
1987 AX 10E Pino
I have a LHD car but, I dont the have the wiring diagram of the thermostat.
My Citroens update:
- jsp
CX 2x GTI turbo
ID 19 1960
Now:
1960 ID 19
1984 CX GTI Turbo 1
1987 CX GTI Turbo 2
1987 AX 10E Pino
My Citroens update:
- xantia_v6
- Lexia Available: Yes
- My Cars: -
1997 Citroen Xantia V6 (France)
1999 Citroen XM V6 ES9 (France)
2011 Peugeot 308 CC THP 155 (NZ)
1975 Jaguar XJ-S pre-HE (NZ) - x 835
That appears to be a controller for the compressor clutch, probably for vehicles with "manual" A/C systems. Which model and year of vehicle did it come from?
- jsp
CX 2x GTI turbo
ID 19 1960
Now:
1960 ID 19
1984 CX GTI Turbo 1
1987 CX GTI Turbo 2
1987 AX 10E Pino
saxo 1997 sanden system. Manual system yes.
My Citroens update:
- jsp
CX 2x GTI turbo
ID 19 1960
Now:
1960 ID 19
1984 CX GTI Turbo 1
1987 CX GTI Turbo 2
1987 AX 10E Pino
Does anyone has the diagram of the Berlingo 1.9D a/c system?
My Citroens update:
- jsp
CX 2x GTI turbo
ID 19 1960
Now:
1960 ID 19
1984 CX GTI Turbo 1
1987 CX GTI Turbo 2
1987 AX 10E Pino
So after a few month and 50 calls around seems noone knows it?
My Citroens update:
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5741
What exactly do you want? Mechanical diagram, electrical diagram???
